WD PCB BAD PINNACLE
sempre
WD PCB BAD PINNACLE
Postby sempre » 27.12.12, 13:17
Hi to all! :mrgreen:
WD250ABYS-18B7A0 (HDD BAD)
FW: 3B05
DATA CODE: 29 MAY 2011
The problem connecting the hdd it does not turn the platter and gets busy.
I have several donors (03).
Not accesses SA (HOT SWAP). Not accepting loaders (mod 11).
Should I try to change the engine chip? (pcb) :idea:
nothing is impossible!
arvika
Re: WD PCB BAD PINNACLE
Postby arvika » 06.01.13, 01:08
Isolate the head connector and power on. If drive spins up, probably heads are gone.
