Maxtor 80 GB after spinning up has starnge sound Topic is solved
mojimorady
Postby mojimorady » 13.12.12, 12:40
dear guru accept my regards
nowadays I am involved with a H.D.D in the following specification :
6Y080l0422611 , YAR41BW0
when i just connet it to power supply , after spinning up it makes a strange sound but obviously it is not head click , something like this : DEEEED , DEEEEED .... .
what kind of proble do you guess it has ?
thank you in advance
Mojtaba Morady
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
Filipp_TS
Re: Maxtor 80 GB after spinning up has starnge sound  Topic is solved
Postby Filipp_TS » 22.04.13, 09:19
Hello!
What a LEDs are lighting?
Is it ready to work after power supply?
What a log in PC3000?
Postby AJ2008 » 25.04.13, 13:29
does the motor spin? Usually on these cases with bad motor it makes musical beeping sound, otherwise you should make sure PCB is 100% good, maybe test it on donor HDD
Return to “Maxtor”
