WD3200AAKS-00UU3A0
Date: 05 MAY 2010
DCM: HGNNTJAHN
If you need any other number, I will provide them
Thanks in advanced,
Rom and Modules for WD3200AAKS
Re: Rom and Modules for WD3200AAKS
Repairs to service area objects are in most cases totally dependant on matching the firmware revision, we need to know the revision of your patient HDD
The firmware version is 3.0B
Where do you find this code?
FW should be similar to "00000023" and ROM should look like "00.23B"
I never see simply '03B' before. Do you read header from mod #11, or select 'View Module 90 information" option?
Here we go:
Techno mode key
ROM version............................. : 00.0JB
ROM generation.......................... : 00.0JB
Link table version...................... : 03.0B.
Consolidated ROM version................ : 0000000J
ROM Modules:
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 156 336 (24)
ROM Firmware version.................... : 0000000J
View module 90 information
Total heads............................. : 2
Used heads.............................. : 2
Mdl 47 version.......................... : FU.0021
ROM Version version..................... : 0000000J (00.0J)
Mdl 11 Version.......................... : 0000000J (00.0J)
Thanks for the help,
Techno mode key
ROM Modules:
