Rst 0x40M
MC Internal LPC Process
(P) SATA Reset
(P) SATA Reset
SIM Error 1009
RW Error 00000080
(SCTWS) Not Hard/Soft Reset, ResetEvent = 0000
SIM Error 3005
RW Error 00000080
User Data Base 00991C00
MCMainPOR: Start:
MCInitialize: Start: Buffer Words VBM: 00000210
MCMainPOR: EXCEPTION: MC Init Fail. Feature disabled.
MCMainPOR: MCTBufferPtr->Header.MCStateFlagsDisc = E59FF018
MCMainPOR: MCTBufferPtr->Header.MCTStateFlags = 0000F018
MCMainPOR: MCStateFlags = 00000000
MCMainPOR: EXCEPTION: POR Failed General
SIM Error 1009
RW Error 00000080
No HOST FIS-ReadyStatusFlags 0002A1A5
Stay at BSY.
i can reach F3 T> with short circuit.
i cant reach ID and the datas.
Any solution ?
ST2000DL003 CC31 problem
Re: ST2000DL003 CC31 problem
Had a lot of this and similar problems reported from new Seagate drives, but no ready solution is found at that time.
- datasolution
cetiner wrote:Rst 0x40M
(P) SATA Reset
(P) SATA Reset
SIM Error 1009
RW Error 00000080
SIM Error 3005
RW Error 00000080
MCMainPOR: Start:
SIM Error 1009
RW Error 00000080
Stay at BSY.
Any solution ?
DEAR FRIEND DID YOU GET SOLUTION FOR THIS ? I HAVE RECIVED SIMILAR PROBLEM AFTER GETTING NO HOST FIS READY STATUS FLAG 0002A1A5 than PRESS CTRL+Z YOU CAN ACCESS F3T> THAN i4,1,22 N1 and m0,6,2,,,,,22 .power off/on afterthat drive becomes ready go to drive id u can see full details like model no,srno, lba etc but still u cant access sectors n again drive becomes busy with led err.If u find solution pls pass me as i dont have solution.THANKS IN ADVANCE.
