Hi to all,
I have a strange problem with this Hdd.
Using pc3Kudma related utility, i can see all cp are good and i can read G-list and Smart. Seem all ok !!!
But when i try to clone it by DE, i see a fast reading but with more Dark-Green sector (Crc Errors).
I see G-list have 48 bad sector. I Clear it and now i have 0 bad sector on G-list. I run again clone with DE, and i see again Dark-Green sector.
I see again G-list and instead 0 i see 90 bad sector. In a few words, any time i start clone with DE each dark-green sector was added to G-list.
There are some way to block G-list add sectors ?
Anyone know this problem ? Is a Toshiba typical problem ?
Tnks to all
Toshiba MK3261GSYN
Re: Toshiba MK3261GSYN
Quite often see this.
Deepspar imager usually manages to clone these ok, for some strange reason!
Have you tried this : viewtopic.php?f=41&t=7732&start=0
Ferry Suryakusuma
PT HDD Studio Data Recovery Indonesia
Yes i just tied that. Now i suppose the problem was a bad head. Now try to shap it and after i tell you result.
Tnks to all for help.
Bye
Bye
