ST31000520AS IS BSY
hamidsamet
ST31000520AS IS BSY
Postby hamidsamet » 15.09.12, 15:28
dear guru
i have a hdd in the following specification :
SEAGATE ST31000520AS Barracuda LP
capacity : 1TB
firmware : CC32
when i connect it to pc3000 udma , it remains busy , heads sound is ok .
try Solution for problem "HDD Look (LED: 000000CC)" Result: unsuccessfully
lots of appreciation for all your help in advance
Best Wishes
H.Samet
Re: ST31000520AS IS BSY
Postby ACE_Admin » 21.09.12, 16:41
Please connect terminal adapter and see the terminal output.
Then try pressing ctrl-z and see if F3 T> output appear there.
Most likely this drive has one common problem we unfortunately haven't got any solution.
hamidsamet
Postby hamidsamet » 22.09.12, 14:47
dear Roustam
this solution does not answer
terminal adapter output DOES NOT SHOW ANYTHING THERE
the stage CTRL-Z does not work
best wishes
Best Wishes
H.Samet
