Samsung SP2014N (200 GB)
jmcurtis81
Postby jmcurtis81 » 25.07.12, 08:47
Hi All I have a Samsung SP2014N
Has a bad PCB, swapped with doner, drive powers up and starts to get ready then powers down
Here is the terminal output
lltst 0000
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0001
DAC: A992
SK C: 0001904E
ENG>SRV>
SvoTbl Loaded
BD
FdtTbl Loaded
Sb <-------------------powers down here
WriteSctLog -- buffer not valid
Any suggestions please??
:cry:
Re: Samsung SP2014N (200 GB)
Postby AJ2008 » 25.07.12, 10:22
Is there external ROM to swap? Seems like ROM is not compatible with SA. Did you try hotswap to reach SA?
jmcurtis81
Postby jmcurtis81 » 26.07.12, 01:00
Hey Aj,
Thanks for your reply!
No external ROM.
I tried Hotswap but didn't work for some reason, luckily if found another drive i'm going to try that now
Jason
Postby AJ2008 » 27.07.12, 09:53
OVerlays and ROM should have same revision. If you cannot find ROM to match Overlays, write overlays to match ROM you do have
Postby Amarbir[CDR-Labs] » 28.07.12, 19:53
jmcurtis81 wrote:Hey Aj,
No external ROM.
Jason
Jason ,
What Was The Result ?
jmcurtis81
Postby jmcurtis81 » 30.07.12, 04:23
Hi again,
I tried hot swap following this guide : Steps for hot-swapping all Samsung drive families: - viewtopic.php?f=33&t=6531
using the following module:
"06 CONFIG"
"10 SLISTHDR"
"11 SLIST"
"12 TLIST"
"13 ALIST"
"5D CONFIG2" (if it exist in modules table)
"62 ALISTHDR" (except PANGO, VANGOPLUS, VELOCE, RUBICON, P80A)
Still unable to see any sectors.
How do I tell if my doner is ok for hot swap? both have PV - MS on label.
Jason
Postby AJ2008 » 30.07.12, 10:16
AJ2008 wrote:OVerlays and ROM should have same revision. If you cannot find ROM to match Overlays, write overlays to match ROM you do have
Postby Amarbir[CDR-Labs] » 30.07.12, 14:56
jmcurtis81 wrote:Hi again,
"06 CONFIG"
"10 SLISTHDR"
"11 SLIST"
"12 TLIST"
"13 ALIST"
Jason
Jason ,
Try What sir is Saying ,These Two Have To Match As The Overlays Are code That Has To Be Executed To complete the Process Of Initialization
jmcurtis81
Postby jmcurtis81 » 01.08.12, 08:28
Hi again,
I think I may have jumped the gun and copied the patient drives "overlay" module onto my doner drive and now it is doing the exact same thing that the patient drive is doing :oops:
and its the only working drive like it that i have!
Have I stuffed this now? anyway to get the doner to have his overlay file back?
thanks again
Jason
Postby AJ2008 » 01.08.12, 10:11
You need to reach SA access to donor and write donor overlays back. This can be achieved only through hotswap in my experience. Use a second donor to get SA access to first donor to restore.
Then write donor overlays to patient SA and use donor PCB to get user data,
Postby Amarbir[CDR-Labs] » 01.08.12, 17:13
AJ2008 wrote:You need to reach SA access to donor and write donor overlays back. This can be achieved only through hotswap in my experience. Use a second donor to get SA access to first donor to restore.
Hello AJ2008 ,
Concentration and not rushing matters is very critical when R&D is going on .
Postby AJ2008 » 01.08.12, 20:51
Hello AJ2008 ,
Sorry, but I dont understand the relevance of your statement? Is it aimed to me? :?:
jmcurtis81
Postby jmcurtis81 » 02.08.12, 07:52
Pretty sure that was aimed at me :oops:
hehe
Ok I will try that, thanks for your advice.
as for the previous advice about the overlays, what am I doing wrong?
I wrote the patient overlay to doner HDD, which "stuffed" it.
i am only new to Pc3000 and still have many things to learn.
jason
Postby Amarbir[CDR-Labs] » 03.08.12, 16:04
Hello AJ2008 ,
Nope ,
It Was Jason :mrgreen: .He Is a Fast Learner :mrgreen:
