WD5000AAJS-00TKA0 ROM need
cetiner
Postby cetiner » 13.07.12, 16:01
Hi to all,
Can anyone help me need ROM for WD5000AAJS-00TKA0
ozgurcetiner@tekniknokta.com.tr
Thank you,
Re: WD5000AAJS-00TKA0 ROM need
Postby AJ2008 » 13.07.12, 16:29
To use a replacement / Donor ROM it needs to be of the same corresponding revision as your patient one.
You need to write here what revision of ROM you need.
But TK series is Tornado, ROM should be internal and ROM recovery process should work well for you, unless there are other problems apart from ROM / PCB?
