A WD2000jb , it has head 0,2,3,4,5
I found the head 0,3 is bad for use Head Test
Can i Remoe head 0,3 by use [test]-[Remove head] function?
Many thanks for your
Can I Remove head 0?
Re: Can I Remove head 0?
No, but depending what model it is you can maybe 'pair' the heads in RAM to replace bad head with functional head.
Other option would be to attempt HotSwap
Thanks for aj2008
I has try use [test]-[Remove head] function to repair a WD5000BEVT
I remove head 2 and Now wd5000bevt is show wd3600bevt
So If I want to repair harddisk and not to recover data
Can I remove head 0?
Because I know head 0 is important for harddisk.
