I need loader for WD10EARS-00MVWB1 FW Vers: 00200076
The drive is from family Sadle G6
Heads map............................... : 0,1,5,7
ROM Firmware version.................... : 00200076
Thank you in advance
WD10EARS-00MVWB1 FW Vers: 00200076 (20.76E) LDR needed
Re: WD10EARS-00MVWB1 FW Vers: 00200076 (20.76E) LDR needed
Haven't got the exact one, anyway I have 00200085. Here is 11th file attached. Try my loader if it will work with your drive.
If you like I can provide you whole SA for this drive.
- Attachments
- 11.rar
- (331.06 KiB) Downloaded 376 times
I will try to use this.Thank you so much Roustam.
Are you sure a loader will help with this model?
what symptoms does it show?
