hi all
i have maxtor STM31000340AS.I can not access terminal.i try evreything but still not work.can any help??PLZ
diamond max22 bsy
Re: diamond max22 bsy
Post the full details, including FW. It is possible this case may require alternative process to get terminal access, such as short circuit.
the FW:MX15
i try by short point.but after i have F3 T> and i press Ready the led error show again and sometimes whean i type Z in terminal i have LED erro
MX15 needs no special workaround, though suspect you are attempting to access T> without isolating PCB first.
You need to ensure PCB is detached from HDA first.
