HD SAS FUJITSU - MBA3147RC
Moderator: Sergey_TS
Alexandre Silveira
Postby Alexandre Silveira » 23.03.12, 12:47
Dear Friends
I have a Fujitsu HD SAS model MBA3147RC where I can not access the data area to retrieve the information.
He presents the following symptoms;
1. Starts the spindle motor = OK
2. After beginning not calibrated, it is emitting sounds metallic.
3. Analysis of PCB has no signs of chips or components visibly damaged.
I need help to try to recover the data, if someone has had some experience and solution to apply.
I thank all
Alexandre
Photo of model HDD SAS
IMG 1.png (377.49 KiB) Viewed 20062 times
Re: HD SAS FUJITSU - MBA3147RC
Postby ACE_Admin » 26.03.12, 16:43
That was solved by making a hot swap and reading with "Long reading" option.
Alexandre Silveira
Postby Alexandre Silveira » 31.03.12, 01:59
This case we have managed to solve here in our company. Hotswap procedures did not work, because the set of heads are damaged.
To retrieve the data we had to replace the head assembly using in our clean room.
HDA Patient and Donor
IMG 2.png (667.86 KiB) Viewed 20044 times
Return to “Fujitsu”
