ST980411ASG DE17 MB ()
drdoc
Postby drdoc » 23.02.12, 06:49
Model : ST980411ASG
Serial : 5TF06XNH
Firmware : DE17
Capacity : MB ()
takes 40 seconds to come ready - but shows 0 mb
f3-terminal is available and lots of commands work
but fix for 0 mb doesnt work.
also cant edit hd id
It recalibrates once after power up but doesnt seem like its getting the full calibration.
Heres the log for fix 0 mb
Requesting FW Pkg ver ........
User Partition Format Successful - Elapsed Time 0 mins 00 secs
Collecting Sys Files Infos...
F3 T> Len
0 4 Reserved Defect Table (SA defect table)
3 3787 Primary Defect File (P-List))
4 12 Servo Adaptive Parameter File (SAP)
8 4800
9 1 SMART Configuration File
A 2259 SMART Data File
B 1000
D 160
F 223 DIC Dummy File
16 2
17 40
19 24 Log File
1A 33 Log File
1B 1 Log File
1C 9
26 80 Drive Self Test (DST), Head 4
27 80 Drive Self Test (DST), Head 5
28 80 Drive Self Test (DST), Head 6
29 80 Drive Self Test (DST), Head 7
2B 1160 R/W Operating Parameters (translator, etc)
2F 432 Data Integrity Check (DIC), HEAD 4
30 432 Data Integrity Check (DIC), HEAD 5
31 432 Data Integrity Check (DIC), HEAD 6
32 432 Data Integrity Check (DIC), HEAD 7
33 4576
35 26 SMART Data
Collecting DT Infos...
ID MemOffs Len
0 6020100 33792 Read Adaptive Parameters File (RAP)
1 6020000 256 Controller Adaptive Parameters File (CAP)
4 4000000 4096 Servo Adaptive Parameter File (SAP)
8 10070000 948
A 60A63FC 1024 Seek Profile
12 100D4000 104
13 60B1250 544 Dependent Zone Table for User Area
14 60B1470 64 Dependent Zone Table for System Area
15 0 524288 Flash ROM
1B 60B0578 3288 Dependent Zone Group Tables for User Area
1C 60B0438 320 Dependent Zone Group Tables for System Area
1D 6020120 208 VBAR Configuration File
1E 6020310 2320 Zone Format Parameters File
ID MemOffs Len
2 60201F0 288 Zone Table
6 20DA40 81956 Servo Flaw Table
8 10070000 948
12 100D4000 104
16 6020100 32 Drive Configuration Table
17 6021F70 1168 Temperature Control Configuration
1F 614466C 1224 RW working user preamp table
20 6144B34 72 RW working system preamp table
Collecting DT Infos completed
Detecting Phys Sct Size...
WARNING! It`s probably HDD have "Translatioin violation (0 GB)" problem
Try the command: Solution for problem "Translation violation (0 GB)"
From menu: Tests -> Solutions
Test : Solution for problem "Translation violation (0 GB)"
HDD capacity restrict. check (SetMax)...
HDD capacity restrict. check (SetMax)............. : Error
SMART erase....................................... : Ok
COM port reconnection...
Translator regeneration........................... : Ok
Solution for problem "Translation violation (0 GB)"......... : Error
Soft reset ...
skype: wayne_horner
Alandata Data Recovery
Continuum
Re: ST980411ASG DE17 MB ()
Postby Continuum » 29.07.13, 03:28
Did you manage to fix this one? I have the same issue.
Postby AJ2008 » 29.07.13, 09:49
The drive is slow to respond, enter command manually at T> and be patient.
Continuum
Postby Continuum » 30.07.13, 01:17
Could you remind me which commands we need to input?
Postby AJ2008 » 31.07.13, 10:22
At T> type "V40" - if any entries are present you need to record these somewhere to re-import them (it should be clear on your model but need to be sure).
Then: "F3 T>m0,6,3,,,,,22"
