WD2500AAJB-00J3A0 Problem with donor pcb
asocla
Postby asocla » 19.02.12, 17:43
I have problems with this disk in the program the "pcb donor" with the original rom and disk modules.
I can get all the details of the SA, I can read perfectly recreate the forms and the rom from them.
When I program the rom ok, I reset the disk and does not give me no problem, but when I copy the forms created with the creation of the ROM disk after I reset the remains of BSY.
Only by reprogramming the ROM can work on it.
Has anyone had the same problem? Do you have any solution?
hassan
Re: WD2500AAJB-00J3A0 Problem with donor pcb
Postby hassan » 20.02.12, 08:26
try to clear smart and run solve "slow responding" problem and clear G-list
asocla
Postby asocla » 20.02.12, 23:53
I tried your solution, but I have not gotten any results.
The PCB is not aligned in any way.
I can remove the modules and recreate the rom, but after reprogramming the PCB I can not work and above the disk is not aligned with remaining on BSY. Launching solv slow problem me error on form 32
hassan
Postby hassan » 22.02.12, 07:11
I think Hot Swap maybe useful
asocla
Postby asocla » 25.02.12, 00:58
I've solved with hot swap procedure. I've recored 100% of files
