WD20EARX donor lost after writing Mod 01
rcz
Postby rcz » 24.01.12, 16:04
I wanted to do a hot-swap with a WD20EARX.
I checked compatibility (averaged Microjogs) -> ok
I wrote Mod 01 by ID from patient to donor -> ok
Off/On donor -> Now I can't get drive ID, I can't get SA SPT (so I put it manually - 1980). I can't neither write any modules, nor use loader (drive restart when I start loader and I get an error).
I wonder if this method is useable on Sadle G6, I had the same problem on a WD20EARS.
An idea ?
hassan
Re: WD20EARX donor lost after writing Mod 01
Postby hassan » 25.01.12, 09:15
Did you try to write modules by ID?
rcz
Postby rcz » 25.01.12, 13:37
Yes, I can't.
hassan
Postby hassan » 25.01.12, 13:52
try to write other rom version and restore the original rom modules (0A,47,..
and try to read module by ID
rcz
Postby rcz » 10.02.12, 15:55
Here it is (sorry for delay, I was in holiday):
Reading modules
Into folder............................. : <HDD Profile>\Data\Modules\
Module : 35............................. : Ok
Module : 33............................. : Ok
Module : 31............................. : Ok
Module : 0C............................. : Ok
Module : 34............................. : Ok
Module : 32............................. : Module ID 32 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module : 36............................. : Module ID 36 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 29............................. : Module ID 29 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 40............................. : Module ID 40 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 41............................. : Ok
Module : 42............................. : Ok
Module : 43............................. : Ok
Module : 4E............................. : Ok
Module : 49............................. : Ok
Module : 4A............................. : Ok
Module : 4D............................. : Ok
Module : 03............................. : Ok
Module : 25............................. : Ok
Module : 26............................. : Ok
Module : 38............................. : Ok
Module : 39............................. : Ok
Module : 37............................. : Ok
Module : 2D............................. : Ok
Module : 2E............................. : Ok
Module : B5............................. : Ok
Module : 6B............................. : Ok
Module : 3A............................. : Ok
Module : 28............................. : Ok
Module : 3B............................. : Ok
Module : 3C............................. : Ok
Module : 3D............................. : Ok
Module : 3E............................. : Ok
Module : 3F............................. : Ok
Module : 6F............................. : Ok
Module : 116............................ : Module ID 116 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 118............................ : Module ID 118 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 119............................ : Module ID 119 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 68............................. : Module ID 68 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 69............................. : Ok
Module : 6A............................. : Ok
Module : 120............................ : Ok
Module : 12D............................ : Ok
Module : 04............................. : Ok
Module : 05............................. : Ok
Module : 3700........................... : Ok
Module : DE............................. : Ok
Module : B6............................. : Ok
Module : D5............................. : Ok
Module : 3426........................... : Ok
Module : 3424........................... : Ok
Module : 3425........................... : Ok
Module : 3411........................... : Ok
Module : D1............................. : Ok
Module : DB............................. : Ok
Module : DF............................. : Ok
Module : DD............................. : Ok
Module : 3413........................... : Ok
Module : 3402........................... : Ok
Module : D7............................. : Ok
Module : D2............................. : Ok
Module : 3300........................... : Ok
Module : 3301........................... : Ok
Module : 3307........................... : Ok
Module : 3303........................... : Ok
Module : 3500........................... : Ok
Module : BB............................. : Ok
Module : 3400........................... : Ok
Module : 3407........................... : Ok
Module : 3405........................... : Ok
Module : D9............................. : Ok
Module : D4............................. : Ok
Module : 3305........................... : Ok
Module : 3429........................... : Ok
Module : DC............................. : Ok
Module : D0............................. : Ok
Module : D3............................. : Ok
Module : F7............................. : Ok
Module : BA............................. : Ok
Module : 3406........................... : Ok
Module : B9............................. : Ok
Module : BC............................. : Ok
Module : 3417........................... : Ok
Module : D8............................. : Ok
Module : BD............................. : Ok
Module : BE............................. : Ok
Module : 3401........................... : Ok
Module : 3302........................... : Ok
Module : 3304........................... : Ok
Module : 3501........................... : Ok
Module : 3502........................... : Ok
Module : 3416........................... : Ok
Module : 3F01........................... : Ok
Module : B8............................. : Ok
Module : BF............................. : Ok
Module : E6............................. : Ok
Module : E7............................. : Ok
Module : 34E7........................... : Ok
Module : 3802........................... : Ok
Module : 3801........................... : Ok
Module : 3418........................... : Ok
Module : 3423........................... : Ok
Module : 3422........................... : Ok
Module : 3511........................... : Ok
Module : 3421........................... : Ok
Module : 3503........................... : Ok
Module : 3F00........................... : Ok
Module : 3428........................... : Ok
Module : 3504........................... : Ok
Module : 8010........................... : Ok
Module : 802C........................... : Ok
Module : 8035........................... : Ok
Module : 8038........................... : Ok
Module : 803C........................... : Ok
Module : 8016........................... : Ok
Module : 801D........................... : Ok
Module : 8044........................... : Ok
Module : 8031........................... : Ok
Module : 8062........................... : Ok
Module : 8063........................... : Ok
Module : 8041........................... : Ok
Module : 8042........................... : Ok
Module : 800E........................... : Ok
Module : 802D........................... : Ok
Module : 8019........................... : Ok
Module : 802F........................... : Ok
Module : 8034........................... : Ok
Module : 802E........................... : Ok
Module : 8032........................... : Ok
Module : 8017........................... : Ok
Module : 8002........................... : Ok
Module : 800B........................... : Ok
Module : 8005........................... : Ok
Module : 8020........................... : Ok
Module : 8046........................... : Ok
Module : 8045........................... : Ok
Module : 8027........................... : Ok
Module : 8014........................... : Ok
Module : 801C........................... : Ok
Module : 8023........................... : Ok
Module : 801F........................... : Ok
Module : 803A........................... : Ok
Module : 803E........................... : Ok
Module : 8012........................... : Ok
Module : 8026........................... : Ok
Module : 802B........................... : Ok
Module : 8029........................... : Ok
Module : 802A........................... : Ok
Module : 8037........................... : Ok
Module : 803B........................... : Ok
Module : 800F........................... : Ok
Module : 800A........................... : Ok
Module : 8025........................... : Ok
Module : 8009........................... : Ok
Module : 800C........................... : Ok
Module : 8006........................... : Ok
Module : 8018........................... : Ok
Module : 800D........................... : Ok
Module : 8008........................... : Ok
Module : 8024........................... : Ok
Module : 8015........................... : Ok
Module : 8007........................... : Ok
Module : 8065........................... : Ok
Module : 801A........................... : Ok
Module : 8030........................... : Ok
Module : 801E........................... : Ok
Module : 8001........................... : Ok
Module : 8022........................... : Ok
Module : 8064........................... : Ok
Module : 8049........................... : Ok
Module : 805D........................... : Ok
Module : 805E........................... : Ok
Module : 805F........................... : Ok
Module : 8060........................... : Ok
Module : 8061........................... : Ok
Module : 8011........................... : Ok
Module : 803F........................... : Ok
Module : 8040........................... : Ok
Module : 8033........................... : Ok
Module : 8043........................... : Ok
Module : 8000........................... : Ok
Module : 8021........................... : Ok
Module : 8FFC........................... : Ok
Module : 8FFD........................... : Ok
Module : 8FFE........................... : Ok
Module : 8047........................... : Ok
Module : 8048........................... : Ok
Module : 8004........................... : Ok
Module : 8003........................... : Ok
Module : 8028........................... : Ok
Module : 8039........................... : Ok
Module : 803D........................... : Ok
Module : 8036........................... : Ok
Module : 801B........................... : Ok
Module : 8013........................... : Ok
Module : 804C........................... : Ok
Module : 804D........................... : Ok
Module : 804E........................... : Ok
Module : 804F........................... : Ok
Module : 804A........................... : Ok
Module : 804B........................... : Ok
Module : 8050........................... : Ok
Module : 8051........................... : Ok
Module : 8052........................... : Ok
Module : 8053........................... : Ok
Module : 8054........................... : Ok
Module : 8055........................... : Ok
Module : 8056........................... : Ok
Module : 8057........................... : Ok
Module : 8058........................... : Ok
Module : 8059........................... : Ok
Module : 805A........................... : Ok
Module : 805B........................... : Ok
Module : 805C........................... : Ok
Module : 8066........................... : Ok
Module : 8067........................... : Ok
Module : 8068........................... : Ok
Module : 8069........................... : Ok
Module : 806A........................... : Ok
Module : 806B........................... : Ok
Module : 806C........................... : Ok
Module : 806D........................... : Ok
Module : 806E........................... : Ok
Module : C3............................. : Ok
Module : C8............................. : Ok
Module : 1000........................... : Ok
Module : B1............................. : Ok
Module : B2............................. : Ok
Module : 1001........................... : Ok
Module : 1002........................... : Ok
Module : 1009........................... : Ok
Module : 100A........................... : Ok
Module : 1003........................... : Ok
Module : 100C........................... : Ok
Module : 1005........................... : Ok
Module : 1004........................... : Ok
Module : 1007........................... : Ok
Module : 100B........................... : Ok
Module : 100D........................... : Ok
Module : 100E........................... : Ok
Module : 1008........................... : Ok
Module : 91............................. : Ok
Module : AE............................. : Ok
Module : C2............................. : Ok
Module : AA............................. : Ok
Module : AC............................. : Ok
Module : 2904........................... : Ok
Module : C4............................. : Ok
Module : A2............................. : Ok
Module : C5............................. : Ok
Module : 2900........................... : Ok
Module : 2901........................... : Ok
Module : 2903........................... : Ok
Module : 2F00........................... : Ok
Module : 2802........................... : Ok
Module : 2909........................... : Ok
Module : 290A........................... : Ok
Module : 2A02........................... : Ok
Module : 1121........................... : Ok
Module : 1100........................... : Ok
Module : 150F........................... : Ok
Module : 150E........................... : Ok
Module : 150D........................... : Ok
Module : 150C........................... : Ok
Module : 1507........................... : Ok
Module : 1506........................... : Ok
Module : 1505........................... : Ok
Module : 1504........................... : Ok
Module : 1101........................... : Ok
Module : 1503........................... : Ok
Module : 1502........................... : Ok
Module : 1501........................... : Ok
Module : 1500........................... : Ok
Module : 80FE........................... : Ok
Module : 806F........................... : Ok
Module : 3604........................... : Ok
Module : 2077........................... : Ok
Module : 2076........................... : Ok
Module : 2075........................... : Ok
Module : 2074........................... : Ok
Module : 2073........................... : Ok
Module : 2072........................... : Ok
Module : 2071........................... : Ok
Module : 2070........................... : Ok
Module : 2067........................... : Ok
Module : 2066........................... : Ok
Module : 2065........................... : Ok
Module : 2064........................... : Ok
Module : 2063........................... : Ok
Module : 2062........................... : Ok
Module : 2061........................... : Ok
Module : 2060........................... : Ok
Module : 2057........................... : Ok
Module : 2056........................... : Ok
Module : 2055........................... : Ok
Module : 2054........................... : Ok
Module : 2053........................... : Ok
Module : 2052........................... : Ok
Module : 2051........................... : Ok
Module : 2050........................... : Ok
Module : 2047........................... : Ok
Module : 2046........................... : Ok
Module : 2045........................... : Ok
Module : 2044........................... : Ok
Module : 2043........................... : Ok
Module : 2042........................... : Ok
Module : 2041........................... : Ok
Module : 2040........................... : Ok
Module : 2017........................... : Ok
Module : 2016........................... : Ok
Module : 2015........................... : Ok
Module : 2014........................... : Ok
Module : 2013........................... : Ok
Module : 2012........................... : Ok
Module : 2011........................... : Ok
Module : 2010........................... : Ok
Module : 2037........................... : Ok
Module : 2036........................... : Ok
Module : 2035........................... : Ok
Module : 2034........................... : Ok
Module : 2033........................... : Ok
Module : 2032........................... : Ok
Module : 2031........................... : Ok
Module : 2030........................... : Ok
Module : 2027........................... : Ok
Module : 2026........................... : Ok
Module : 2025........................... : Ok
Module : 2024........................... : Ok
Module : 2023........................... : Ok
Module : 2022........................... : Ok
Module : 2021........................... : Ok
Module : 2020........................... : Ok
Module : 2007........................... : Ok
Module : 2006........................... : Ok
Module : 2005........................... : Ok
Module : 2004........................... : Ok
Module : 2003........................... : Ok
Module : 2002........................... : Ok
Module : 2001........................... : Ok
Module : 2000........................... : Ok
Module : 9A............................. : Ok
Module : A0............................. : Ok
Module : A5............................. : Ok
Module : A9............................. : Ok
Module : 97............................. : Ok
Module : 96............................. : Ok
Module : 94............................. : Ok
Module : C9............................. : Ok
Module : C6............................. : Ok
Module : 93............................. : Ok
Module : CE............................. : Ok
Module : CF............................. : Ok
Module : 98............................. : Ok
Module : 99............................. : Ok
Module : CA............................. : Ok
Module : CC............................. : Ok
Module : 128............................ : Ok
Module : 121............................ : Ok
Module : 3C00........................... : Ok
Module : AF............................. : Ok
Module : 9E............................. : Ok
Module : FA............................. : Ok
Module : C7............................. : Ok
Module : 3E00........................... : Ok
Module : FC............................. : Ok
Module : 280A........................... : Ok
Module : 9C............................. : Ok
Module : EE............................. : Ok
Module : 11............................. : Module ID 11 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module : 01............................. : Ok
Module : FD............................. : Ok
Module : C1............................. : Ok
Module : B7............................. : Ok
Module : 5C............................. : Ok
Module : 122............................ : Ok
Module : 6D............................. : Ok
Module : 4002........................... : Ok
Module : AC55........................... : Ok
Module : 6E............................. : Ok
Module : 1F............................. : Ok
Module : 62............................. : Ok
Module : 61............................. : Ok
Module : 115............................ : Ok
Module : 53............................. : Ok
Module : 52............................. : Ok
Module : 51............................. : Ok
Module : 50............................. : Ok
Module : 12............................. : Ok
Module : 19............................. : Ok
Module : 24............................. : Ok
Module : 23............................. : Ok
Module : 21............................. : Ok
Module : 2A............................. : Ok
Module : 2F............................. : Ok
Module : 1E............................. : Ok
Module : 15............................. : Ok
Module : 14............................. : Ok
Module : 1C............................. : Ok
Module : 17............................. : Ok
Module : 02............................. : Ok
Module : 109............................ : Ok
Module : 108............................ : Ok
Module : 106............................ : Ok
Module : 105............................ : Ok
Module : 104............................ : Ok
Module : 103............................ : Ok
Module : 102............................ : Ok
Module : 110............................ : Ok
Module : AD............................. : Ok
Module : 1430........................... : Ok
Module : 1102........................... : Ok
Module : 121F........................... : Ok
Module : E0............................. : Ok
Module : E1............................. : Ok
Module : E2............................. : Ok
Module : E3............................. : Ok
Module : E4............................. : Ok
Module : E5............................. : Ok
Module : FE............................. : Ok
Module : 120F........................... : Ok
Module : 1213........................... : Ok
Module : 2906........................... : Ok
Module : 2908........................... : Ok
Module : E8............................. : Ok
Module : E9............................. : Ok
Module : EA............................. : Ok
Module : EB............................. : Ok
Module : EC............................. : Ok
Module : ED............................. : Ok
Module : 1400........................... : Ok
hassan
Postby hassan » 20.02.12, 08:43
Now try to rewrite module 11 from the same FW version
rcz
Postby rcz » 20.02.12, 11:12
I have "Error code 3745" when I try to write any module.
hassan
Postby hassan » 20.02.12, 12:46
Try to write modules by ID
rcz
Postby rcz » 20.02.12, 17:53
This error happens when I write by ID, I can't access to modules by ABA
hassan
Postby hassan » 22.02.12, 07:03
If you can read and write SA Tracks try to write the original SA tracks
Towerrat79
Postby Towerrat79 » 30.03.12, 09:52
Hassan
Thank your for the tip on rewriting the donor's original Service Tracks. I did this and the drive came back to life!
Frank
Frank Meincke
Gefund-IT (Datenrettung)
Daimlerstrasse 70
74545 Michelfeld
tel: 0791-94 66 68 52
email: Info@Gefund-IT.de
web: www.Gefund-IT.de
mojimorady
Postby mojimorady » 29.01.14, 10:08
hi
Actually I Need loader and Rom And Rom modules of this model
is that possible for you to share them with me ???
best regards
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
