HDT722525DLA380 ABR Error
rcz
Postby rcz » 12.01.12, 09:48
This Hard Drive has falled. Now it shows DRD DSC but sizzle a little and answer ABR at ID request.
I change heads but it doesn't helped at all (platters surfaces seems in good condition).
A lot of modules are broken, but maybe because Open module table isn't read. Here is Structure test :
SA structure test.zip
(846 Bytes) Downloaded 536 times
Do you have an idea if something can be done with it ?
dmarques
Re: HDT722525DLA380 ABR Error
Postby dmarques » 12.01.12, 17:29
What are the modules that can't be read?
rcz
Postby rcz » 13.01.12, 08:39
SA structure test.zip --->
Loading data for correction of HDD family handling settings from section MEM_P
Selected family......................... : DLAT
NV-RAM reading.......................... : Ok
Module not read (USAG)
Error : Device error detected (UNC)
Loading modules table................................................. : Ok
Error :............................................................... : Error executing loading "open" modules dir command
Loading zone allocation table......................................... : Ok
Test : SA structure test
Module checking
Module RSVD Copy 0...................... : Error
Module RSVD Copy 1...................... : Ok
Module RSVD Copy F...................... : Error
Module USAG Copy 0...................... : Error
Module USAG Copy 1...................... : Ok
Module USAG Copy F...................... : Error
Module PSHT Copy 0...................... : Error
Module PSHT Copy 1...................... : Error
Module PSHT Copy F...................... : Error
Module RDMT Copy 0...................... : Error
Module RDMT Copy 1...................... : Error
Module RDMT Copy F...................... : Error
Module RLBA Copy 0...................... : Error
Module RLBA Copy 1...................... : Ok
Module RLBA Copy F...................... : Error
Module CNSL Copy 0...................... : Error
Module CNSL Copy 1...................... : Error
Module CNSL Copy F...................... : Ok
Module RWCN Copy 0...................... : Ok
Module RWCN Copy 1...................... : Error
Module RWCN Copy F...................... : Ok
Module CHNM Copy 0...................... : Error
Module CHNM Copy 1...................... : Error
Module CHNM Copy F...................... : Error
Module SRVP Copy 0...................... : Ok
Module SRVP Copy 1...................... : Error
Module SRVP Copy F...................... : Ok
Module SRVM Copy 0...................... : Error
Module SRVM Copy 1...................... : Error
Module SRVM Copy F...................... : Error
Module ZONE Copy 0...................... : Error
Module ZONE Copy 1...................... : Error
Module ZONE Copy F...................... : Error
Module PTRT Copy 0...................... : Error
Module PTRT Copy 1...................... : Error
Module PTRT Copy F...................... : Error
Module RAM0 Copy 0...................... : Error
Module RAM0 Copy 1...................... : Ok
Module RAM0 Copy F...................... : Error
Module OVR1 Copy 0...................... : Error
Module OVR1 Copy 1...................... : Error
Module OVR1 Copy F...................... : Error
Module SMRT Copy 0...................... : Ok
Module SMRT Copy 1...................... : Error
Module SMRT Copy F...................... : Ok
Module MLBA Copy 0...................... : Ok
Module MLBA Copy 1...................... : Ok
Module MLBA Copy F...................... : Ok
Module SECI Copy 0...................... : Ok
Module SECI Copy 1...................... : Error
Module SECI Copy F...................... : Ok
Module SRIF Copy 0...................... : Error
Module SRIF Copy 1...................... : Error
Module SRIF Copy F...................... : Ok
Module SERL Copy 0...................... : Error
Module SERL Copy 1...................... : Error
Module SERL Copy F...................... : Error
Module IDNT Copy 0...................... : Error
Module IDNT Copy 1...................... : Error
Module IDNT Copy F...................... : Ok
Module DCOT Copy 0...................... : Ok
Module DCOT Copy 1...................... : Error
Module DCOT Copy F...................... : Ok
Module PTCH Copy 0...................... : Error
Module PTCH Copy 1...................... : Error
Module PTCH Copy F...................... : Error
Module ##01 Copy 0...................... : Ok
Module ##01 Copy 1...................... : Error
Module ##01 Copy F...................... : Ok
Module ##02 Copy 0...................... : Ok
Module ##02 Copy 1...................... : Error
Module ##02 Copy F...................... : Ok
Module ##03 Copy 0...................... : Ok
Module ##03 Copy 1...................... : Error
Module ##03 Copy F...................... : Error
Module ##04 Copy 0...................... : Ok
Module ##04 Copy 1...................... : Error
Module ##04 Copy F...................... : Error
Module PESD............................. : Error
Module SRST............................. : Error
Module SSSC............................. : Ok
Module SSCD............................. : Error
Module NVRC............................. : Error
Module PIDM is not found!
Module not created! PIDM
Module MFGP is not found!
Module not created! MFGP
rcz
Postby rcz » 17.01.12, 11:07
Nobody can help me ? :roll:
