Hi all,
I have here a Seagate with Terminal output: "FreeFall Sensor is enabled by default"
And the led BSY is green.
First i tried the LED:000000CC Solution by isolation the motorcontact.
The Drive complete the solution successful, and then switched off an on. Now the problrm is the same.
Drive not ready.
BSY is green and this is the output from terminal:
Rst 0x10M
(P) SATA Reset
PASSPackage Verified
RW: Error processing Performance Parameter File: 203A
LED:000000CD FAddr:00010943
Where is this FreeFall Sensor and could it be replaced?
Thanks for help
Bruno
Seagate Momentus 7200.3 ST9160411ASG
Re: Seagate Momentus 7200.3 ST9160411ASG
Problem solved
After tried the CC-solution many-many times (shorting contact and place isolation alternately), i tried to solve the Problem in Terminal manuell.
Now the drive works fine.
Thank you ACELab
Thank you ACELab
