WD5000AAKS-00TMA0
Bruno
WD5000AAKS-00TMA0
Postby Bruno » 24.10.11, 19:40
Hi all,
Did any of you see problem like that on a WD HDD, and how i can be solve?
All Modules are good, all Heads are good, but the first 383'000'000 produce many read errors on all heads. But from 383'000'000 till the end (976'773'167) i could read all sectors normaly...
Thanks for help.
Bruno
hassan
Re: WD5000AAKS-00TMA0
Postby hassan » 25.10.11, 09:41
You can try regenerate Translator
Bruno
Postby Bruno » 25.10.11, 12:19
Hi Hassan, thanks for answer.
I try it, befor i write in this forum, but no access to the most of first 383'000'000 sectors.
Alexii
Postby Alexii » 26.01.12, 20:31
Reply is to late, but for anyone having same problem : This is a WD Tornado family with classic Tornado issue. Put a new PCB on it , write original ROM or recreate ROM from SA and u got it =)
Bruno
Postby Bruno » 27.01.12, 09:29
Hi Alexii,
You are welcome.
Thanks for answer ,anyway. You are right, the case is closed.
Bruno
pcimage
Postby pcimage » 28.01.12, 00:43
Nice one Alexeii
Good advice
