pb with WD 1 To MY BOOK
eurlamp
Postby eurlamp » 09.09.11, 22:22
I have 2 identical WD 1To ( My Book model) from 2 differents customers.
They have the same problem. They are well recognized but they are 4 empty partitions in DE. I can't find nothing in raw recovery mode.
Does someone have an idea or a way to recover my customers data? These HDDs are not encrypted by a password and are in NTFS.
Thanks by advance
François
hassan
Re: pb with WD 1 To MY BOOK
Postby hassan » 10.09.11, 18:04
This drive have SmarWare software so you should conect the drive to mybook usb pcb and connect this drive to your PC as usb disk then run DE
dmarques
Postby dmarques » 12.09.11, 09:33
Are you connecting the drive by USB?
eurlamp
Postby eurlamp » 17.09.11, 17:29
thanks a lot. I try to connect the hdd in sata so I can't find datas. I try to connect in usb and it is working fine withe the upgrade of pc3k
