I have the drive above that does not become ready.
When entering the utility, It does not detect the drive ID.
When I try to short the points and try the solution to 00000CC, The drive spins down, then I get
F3 T>
ASCII DIAG MODE
F3 T>
ASCII DIAG MODE
F3 T>
ASCII DIAG MODE
repeating.
The spindle stops. Then when I click ready, the drive spins up, but then I get "drive not ready"
Has anyone had this problem?
St3250318AS CC38 not ready
Re: St3250318AS CC38 not ready
Try to perform recovery steps manually.
I mean, run solution for LEDCC problem and when motor will be stopped and F3T will appear, press on CANCEL button.
Go to terminal, spin up the motor by terminal commands:
F3 2>U
And then try to clear Smart/Glist.
Paste here logs.
F3 2>U
Paste here logs.
You are sure you short correct points?
If short circuit is good heads should knock and 'T>' will be accessible. After some seconds knocking will stop and you still have DRDY and 'T>' and can make spindown command.
After spinup Terminal access should be still present.
does spindle stop without short circuit? If so maybe heads are damaged.
