WD10EAVS-00D7B1 loader needed.
Continuum
Postby Continuum » 08.07.11, 07:53
Hii,
I am after a loader for the drive above.
Firmware details are:
Techno mode key
Dir info (0B)........................... : 0 (0)
ROM version............................. : 05.DGE
ROM generation.......................... : 05.DGE
Link table version...................... : 04.3G.
Caclulated Version...................... : 000500DG
Head map................................ : 2,3,4,5,6,7
ROM Firmware version.................... : 000500DG
Drive spins up but does not detect. -detects as ()Mb
Keeps spinning, but does not become ready.
Can anyone help with modules/Ldr?
hassan
Re: WD10EAVS-00D7B1 loader needed.
Postby hassan » 09.07.11, 11:42
Try to set jumper to kernel mode
Save the original rom and rom modules
and rewrite other rom version
then restore original modules(47,30,0A) and run the drive in normal mode then start SA Structure test and send me the log
Continuum
Postby Continuum » 24.08.11, 08:18
hassan wrote:Hello
Thanks Hassan,
The instructions seem a little confusing to me. When I put a PCB with same firmware(00D7B1 - not 000500BM) and read the modules by ID, I get:
Reading modules
Into folder............................. : <HDD Profile>\Data\Modules\
Module : 01............................. : Ok
Module : 35............................. : Ok
Module : 6D............................. : Ok
Module : 110............................ : Module ID 110 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 102............................ : Module ID 102 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 103............................ : Module ID 103 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 104............................ : Module ID 104 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 105............................ : Module ID 105 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 107............................ : Module ID 107 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 106............................ : Module ID 106 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 108............................ : Ok
Module : 02............................. : Module ID 02 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 17............................. : Module ID 17 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 1B............................. : Module ID 1B reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 1C............................. : Ok
Module : 14............................. : Ok
Module : 15............................. : Ok
Module : 1E............................. : Ok
Module : 2F............................. : Ok
Module : 2A............................. : Ok
Module : 21............................. : Ok
Module : 22............................. : Ok
Module : 23............................. : Ok
Module : 24............................. : Ok
Module : 13............................. : Module ID 13 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module : 80............................. : Module ID 80 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 11............................. : Module ID 11 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 19............................. : Module ID 19 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 12............................. : Module ID 12 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 50............................. : Module ID 50 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 51............................. : Module ID 51 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 52............................. : Module ID 52 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 53............................. : Module ID 53 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 61............................. : Module ID 61 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 62............................. : Module ID 62 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 1F............................. : Module ID 1F reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 6E............................. : Module ID 6E reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 115............................ : Module ID 115 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module : 116............................ : Ok
Module : 118............................ : Ok
Module : AC55........................... : Ok
Module : 4002........................... : Ok
Module : 109............................ : Ok
Module : 121............................ : Module ID 121 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module : 3604........................... : Ok
Module : 33............................. : Ok
Module : 31............................. : Ok
Module : 0C............................. : Ok
Module : 34............................. : Module ID 34 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
Module : 32............................. : Module ID 32 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : 36............................. : Ok
Module : 29............................. : Ok
Module : 40............................. : Ok
Module : 41............................. : Ok
Module : 42............................. : Ok
Module : 43............................. : Ok
Module : 4E............................. : Ok
Module : 49............................. : Ok
Module : 4A............................. : Ok
Module : 4D............................. : Ok
Module : 03............................. : Ok
Module : 04............................. : Ok
Module : 05............................. : Ok
Module : 25............................. : Ok
Module : 26............................. : Ok
Module : 38............................. : Ok
Module : 39............................. : Ok
Module : 37............................. : Ok
Module : 2D............................. : Ok
Module : 2E............................. : Ok
Module : B5............................. : Ok
Module : 6B............................. : Ok
Module : 3A............................. : Ok
Module : 28............................. : Ok
Module : 3B............................. : Ok
Module : 3C............................. : Ok
Module : 3D............................. : Ok
Module : 3E............................. : Ok
Module : 3F............................. : Ok
Module : 6F............................. : Ok
Module : 119............................ : Ok
Module : 68............................. : Ok
Module : 69............................. : Ok
Module : 6A............................. : Ok
Module : DE............................. : Ok
Module : B6............................. : Ok
Module : D5............................. : Ok
Module : 3411........................... : Ok
Module : D1............................. : Ok
Module : DA............................. : Ok
Module : DB............................. : Ok
Module : DF............................. : Ok
Module : DD............................. : Ok
Module : D6............................. : Ok
Module : 3402........................... : Ok
Module : D7............................. : Ok
Module : D2............................. : Ok
Module : 3300........................... : Ok
Module : 3301........................... : Ok
Module : 3400........................... : Ok
Module : BB............................. : Ok
Module : 3405........................... : Ok
Module : D9............................. : Ok
Module : D4............................. : Ok
Module : DC............................. : Ok
Module : D0............................. : Ok
Module : D3............................. : Ok
Module : F7............................. : Ok
Module : BA............................. : Ok
Module : 3406........................... : Ok
Module : B9............................. : Ok
Module : BC............................. : Ok
Module : D8............................. : Ok
Module : BD............................. : Ok
Module : BE............................. : Ok
Module : 3401........................... : Ok
Module : 3302........................... : Ok
Module : B8............................. : Ok
Module : BF............................. : Ok
Module : E6............................. : Ok
Module : E7............................. : Ok
Module : B7............................. : Module ID B7 reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : FA............................. : Ok
Module : FC............................. : Ok
Module : FD............................. : Module ID FD reading error Data request error - Device Error Detected: "FM ERR HEADER II SIGNATURE INVALID"
Module : EE............................. : Ok
Module : 3E00........................... : Ok
Module : 3801........................... : Ok
Module : 3C00........................... : Ok
Module : 3415........................... : Ok
Module : C4............................. : Ok
Module : A8............................. : Ok
Module : A2............................. : Ok
Module : C5............................. : Ok
Module : C3............................. : Ok
Module : C8............................. : Ok
Module : 91............................. : Ok
Module : CC............................. : Ok
Module : CA............................. : Ok
Module : 99............................. : Ok
Module : 98............................. : Ok
Module : CB............................. : Ok
Module : CD............................. : Ok
Module : CF............................. : Ok
Module : CE............................. : Ok
Module : 93............................. : Ok
Module : C1............................. : Ok
Module : C2............................. : Ok
Module : C7............................. : Ok
Module : 9E............................. : Ok
Module : C6............................. : Ok
Module : C9............................. : Ok
Module : 94............................. : Ok
Module : 96............................. : Ok
Module : 97............................. : Ok
Module : AA............................. : Ok
Module : A9............................. : Ok
Module : A5............................. : Ok
Module : A6............................. : Ok
Module : 92............................. : Ok
Module : A0............................. : Ok
Module : A1............................. : Ok
Module : 9A............................. : Ok
Module : 9C............................. : Ok
Module : 2000........................... : Ok
Module : 2001........................... : Ok
Module : 2002........................... : Ok
Module : 2003........................... : Ok
Module : 2004........................... : Ok
Module : 2005........................... : Ok
Module : 2006........................... : Ok
Module : 2007........................... : Ok
Module : 2020........................... : Ok
Module : 2021........................... : Ok
Module : 2022........................... : Ok
Module : 2023........................... : Ok
Module : 2024........................... : Ok
Module : 2025........................... : Ok
Module : 2026........................... : Ok
Module : 2027........................... : Ok
Module : 2030........................... : Ok
Module : 2031........................... : Ok
Module : 2032........................... : Ok
Module : 2033........................... : Ok
Module : 2034........................... : Ok
Module : 2035........................... : Ok
Module : 2036........................... : Ok
Module : 2037........................... : Ok
Module : 2010........................... : Ok
Module : 2011........................... : Ok
Module : 2012........................... : Ok
Module : 2013........................... : Ok
Module : 2014........................... : Ok
Module : 2015........................... : Ok
Module : 2016........................... : Ok
Module : 2017........................... : Ok
Module : 2040........................... : Ok
Module : 2041........................... : Ok
Module : 2042........................... : Ok
Module : 2043........................... : Ok
Module : 2044........................... : Ok
Module : 2045........................... : Ok
Module : 2046........................... : Ok
Module : 2047........................... : Ok
Module : 2050........................... : Ok
Module : 2051........................... : Ok
Module : 2052........................... : Ok
Module : 2053........................... : Ok
Module : 2054........................... : Ok
Module : 2055........................... : Ok
Module : 2056........................... : Ok
Module : 2057........................... : Ok
Module : 2060........................... : Ok
Module : 2061........................... : Ok
Module : 2062........................... : Ok
Module : 2063........................... : Ok
Module : 2064........................... : Ok
Module : 2065........................... : Ok
Module : 2066........................... : Ok
Module : 2067........................... : Ok
Module : 8010........................... : Ok
Module : 802C........................... : Ok
Module : 8035........................... : Ok
Module : 8038........................... : Ok
Module : 803C........................... : Ok
Module : 8016........................... : Ok
Module : 801D........................... : Ok
Module : 8044........................... : Ok
Module : 8031........................... : Ok
Module : 8062........................... : Ok
Module : 8063........................... : Ok
Module : 8041........................... : Ok
Module : 8042........................... : Ok
Module : 800E........................... : Ok
Module : 802D........................... : Ok
Module : 8019........................... : Ok
Module : 802F........................... : Ok
Module : 8034........................... : Ok
Module : 802E........................... : Ok
Module : 8032........................... : Ok
Module : 8017........................... : Ok
Module : 8002........................... : Ok
Module : 800B........................... : Ok
Module : 8005........................... : Ok
Module : 8020........................... : Ok
Module : 8046........................... : Ok
Module : 8045........................... : Ok
Module : 8027........................... : Ok
Module : 8014........................... : Ok
Module : 801C........................... : Ok
Module : 8023........................... : Ok
Module : 801F........................... : Ok
Module : 803A........................... : Ok
Module : 803E........................... : Ok
Module : 8012........................... : Ok
Module : 8026........................... : Ok
Module : 802B........................... : Ok
Module : 8029........................... : Ok
Module : 802A........................... : Ok
Module : 8037........................... : Ok
Module : 803B........................... : Ok
Module : 800F........................... : Ok
Module : 800A........................... : Ok
Module : 8025........................... : Ok
Module : 8009........................... : Ok
Module : 800C........................... : Ok
Module : 8006........................... : Ok
Module : 8018........................... : Ok
Module : 800D........................... : Ok
Module : 8008........................... : Ok
Module : 8024........................... : Ok
Module : 8015........................... : Ok
Module : 8007........................... : Ok
Module : 8065........................... : Ok
Module : 801A........................... : Ok
Module : 8030........................... : Ok
Module : 801E........................... : Ok
Module : 8001........................... : Ok
Module : 8022........................... : Ok
Module : 8064........................... : Ok
Module : 8049........................... : Ok
Module : 805D........................... : Ok
Module : 805E........................... : Ok
Module : 805F........................... : Ok
Module : 8060........................... : Ok
Module : 8061........................... : Ok
Module : 8011........................... : Ok
Module : 803F........................... : Ok
Module : 8040........................... : Ok
Module : 8033........................... : Ok
Module : 8043........................... : Ok
Module : 8000........................... : Ok
Module : 8021........................... : Ok
Module : 8FFC........................... : Ok
Module : 8FFD........................... : Ok
Module : 8FFE........................... : Ok
Module : 8047........................... : Ok
Module : 8048........................... : Ok
Module : 8004........................... : Ok
Module : 8003........................... : Ok
Module : 8028........................... : Ok
Module : 8039........................... : Ok
Module : 803D........................... : Ok
Module : 8036........................... : Ok
Module : 801B........................... : Ok
Module : 8013........................... : Ok
Module : 804C........................... : Ok
Module : 804D........................... : Ok
Module : 804E........................... : Ok
Module : 804F........................... : Ok
Module : 804A........................... : Ok
Module : 804B........................... : Ok
Module : 8050........................... : Ok
Module : 8051........................... : Ok
Module : 8052........................... : Ok
Module : 8053........................... : Ok
Module : 8054........................... : Ok
Module : 8055........................... : Ok
Module : 8056........................... : Ok
Module : 8057........................... : Ok
Module : 8058........................... : Ok
Module : 8059........................... : Ok
Module : 805A........................... : Ok
Module : 805B........................... : Ok
Module : 805C........................... : Ok
Module : 8066........................... : Ok
Module : 8067........................... : Ok
Module : 8068........................... : Ok
Module : 8069........................... : Ok
Module : 806A........................... : Ok
Module : 806B........................... : Ok
Module : 806C........................... : Ok
Module : 1000........................... : Ok
Module : B1............................. : Ok
Module : B2............................. : Ok
Module : 1001........................... : Ok
Module : 1002........................... : Ok
Module : 1009........................... : Ok
Module : 1003........................... : Ok
Module : 1005........................... : Ok
Module : 1004........................... : Ok
Module : 1007........................... : Ok
Module : 1008........................... : Ok
Module : 1504........................... : Ok
Module : 1501........................... : Ok
Module : 1503........................... : Ok
Module : 1101........................... : Ok
Module : 1430........................... : Ok
Module : E0............................. : Ok
Module : E1............................. : Ok
Module : E2............................. : Ok
Module : E3............................. : Ok
Module : E4............................. : Ok
Module : E5............................. : Ok
Module : FE............................. : Ok
Module : FB............................. : Ok
Module : 120F........................... : Ok
Module : 1213........................... : Ok
hassan
Postby hassan » 24.08.11, 12:30
Try the following steps:
1-try to rewrite modules' 1x (11 , 12 , ..)from good copy must be the same FW
2-Also rewrite 34,32 then clear g-list and fill zero module 32 after header
3-restore original ROM aftar power on the drive must start normaly if not then you have to rewrite modules 1x , 32 , 34 to another location on SA you can see WD Marvell Dir module editing viewtopic.php?f=35&t=7181
4-if you can not access user data after drive start normaly try to read module 50 51 52 53 by composite reading and copy them to another location
if steps 1 , 3 not success try Hot-Swap
Continuum
Postby Continuum » 25.08.11, 04:44
Does anyone have the modules from this firmware?
Postby AJ2008 » 07.09.11, 13:30
Your problem here is many overlaes bad.
In this situation I would try Hot-Swap, but you still need to compensate overlaes with same FW version which you do not have.
I have FW version 000500DG, but is from 640GB model. Should be fine. I cannot upload here, I add to megaupload for you :)
http://www.megaupload.com/?d=8OTZTH70
