Loader (FW) for WD800JD-75MSA1 needed
mmingos
Postby mmingos » 28.05.11, 11:27
Patient drive came with another PCB.
Original PCB was lost and the disk had problem with heads also by the guy that sent it because it has changed a lot of hands.
Changed heads from a donor drive.
Now i can Read SA surface is all good.
The drive goes ready but only family is show. Its a Sabre58 (unicorn).
I checked the modules one by one and i see large gaps to module 17,29 ... so i believe they are not correct from where i loaded them.
That's why i need rom contents and modules.
I've searched anywhere but i cannot find firmware, please anybody has this family F/W and ROM ?
Igor
Re: Loader (FW) for WD800JD-75MSA1 needed
Postby Igor » 30.05.11, 09:28
You will find in attachment PCR file that contains several ROMs from SABRE58.
It is better to write FW version that you need, because with different version it will not work.
SABRE58_ROM.rar
(552.75 KiB) Downloaded 371 times
