HI,
i have a model segate 7200.12 320 gb. it has translation problem. i can read sectors up to certain level. but after that cant read sectors . get UNC error. i can read data with active utility command. but its very very slow. so i tried to recover traslator . but i get error at above sector. error is ,
fork direction ambiquity , correct it mannualy.
so add first defect to slip list. and hide. but i get following error on terminal.
Hard reallocate LBA status:error = 00000002:04808781.
i tried G6C command but same error. i tried to clear glist and smart but no help any idea?
ERROR ADDING DEFECT SLIP LIST ON 7200.12 MODEL
Re: ERROR ADDING DEFECT SLIP LIST ON 7200.12 MODEL
This error code stays for "parity writing error". This could be connected to logic board , first things to try is to swap it
with good working donor's board that has original ROM chip from patient.
If that will have no result, please provide us next information:
1.The log from terminal that was before that error.
2.T>V1 command output log
