ST3500418AS problem
ththeod
ST3500418AS problem
Postby ththeod » 18.05.11, 22:23
The drive gets DRD DRC without any clicking but does not ID.
the terminal output of the drive startup is
Code: Select all
Rst 0x10M
Servo Processor Is Reset.
ExecuteSpinRequest
(P) SATA Reset
Without any LED error.
After (P) SATA Reset terminal freezes
i tried shorting the R/W channel they drive remained BSY and i had access to the terminal
it spins up and down ok
I can see Alt list , P-list..
what should i do next?
Re: ST3500418AS problem
Postby ACE_Admin » 03.06.11, 14:16
What is this hard drive Fw version?
Also, haven't you tried to run translator regeneration command?
It is launched over ATA and could help you to solve this problem.
houman_2h
Postby houman_2h » 12.07.13, 20:34
Dear roustam
Before translator how we can backup FW ?
Your answer are appreciated .
Postby AJ2008 » 15.07.13, 10:22
Make sure you save output of 'V40' list before you attempt it, no need to backup anything else
