ST3250318AS
ththeod
ST3250318AS
Postby ththeod » 13.05.11, 17:47
I have a problem with one of those drives.
It does not spin up and in terminal it continuously reports "Rst 0x08M" it seems it's on a loop of hard resets..
If I connect only the PCB the same thing happens. I tested the resistances on the motor coils they are around 8.5 ohm,
I also tried the R/W channel short but still nothing happened.
What should I do next? Should i look for donor pcb?
ththeod
Re: ST3250318AS
Postby ththeod » 13.05.11, 20:15
hm it seems to be the smooth chip
i ll find a donor pcb and post back
Mehdi Sed
Re: ST3250318AS
Postby Mehdi Sed » 15.06.11, 07:12
I have the same problem with HDD STM3250318AS ;
in power on just shows Rst 0x08M and stay in busy without motor powering off,
Spining sound is normal, and check heads result is
Head 00 Resistance 00FA
Head 01 Resistance 00EE
Terminal:
Rst 0x08M
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 281.356 msecs
F3 2>U
HighPowerMode
ExecuteSpinRequest
Spin Up Complete
Elapsed Time 6.934 secs
F3 2>/1
F3 1>N1
Init SMART Fail
LED:000000CC FAddr:0024EE4
Rst 0x08M
PCB changing is not works also donor pcb with native rom not works too.
Thanks and appreciate for any help and solution :)
Mehdi Sed
dmarques
Re: ST3250318AS
Postby dmarques » 22.06.11, 09:49
You can try to regenerate translator before clearing SMART.
