7200.12 ST3160318AS BSY PROBLEM.
OHMYDATA
Postby OHMYDATA » 12.05.11, 13:23
ST3160318AS BSY and no clicking sounds.
FW : HP35
After power on, bsy and no cliking sounds.
Terminal logs.
Rst 0x08M
Servo Processor Is Reset.
ExecuteSpinRequest
No HOST FIS-ReadyStatusFlags 2002A1A5
Please explain "No HOST FIS-ReadyStatusFlags 2002A1A5".
Re: 7200.12 ST3160318AS BSY PROBLEM.
Postby ACE_Admin » 12.05.11, 15:31
Unfortunately there is no certain answer for that error code. I have checked previous cases, "2002A1A5" error stayed for translator or SMART problems.
For the answer to that question you have to try next steps below. First step - you can try to reach translator with ctrl-z and type
T>/1
1>N6
1>N8
That will list you SMART parameters.
If it could display parameters well, you can try to reach defect slip list with T>V1 command.
Drive has to read it properly.
If SMART will report you an error you can try to clear it with N1 command. Sequence is next:
T>/1
1>N1
If there is translator problem, you can clear defect list and regenerate translator with next set of commands:
T>i4,1,22
T>m0,6,2,,,,,22
It is a good idea to save all modules before making any changes to drive.
OHMYDATA
Postby OHMYDATA » 13.05.11, 03:36
Thank you! solved! :P
It's translator problem.
