hi everybody
i have a model
ST3320613AS 7200.11 (320gb). (slim)
Firmware : CC2J
Capacity : 298.09 GB (625 142 448)
i can copy sectors till 85655454 ( 45 GB) without any problem. after that i cant copy sectors . getting this error
Starting LBA of RW Request=05204280 Length=FFFFFFFF
ProcessRWError -Read- at LBA 05204280 Sense Code=C4090082
Unrecoverable Error CB .
i tried differnt ranges and head map. but same error.
i tried to run " recover translator" command but failed at 85655454 sector. i tried to add sectors sliplist manualy . but still fail at same sector.
any solution ( even considering shifting of data)
love regards
sigmaalv
7200.11 reading problem (traslator)
Re: 7200.11 reading problem (traslator)
What was the error you encounter ? Have you backuped the resources before running translator regeneration?
Try clearing defect list and recalculating translator, then try "Translator recovery" process again. When you will see the error within "Log" tab, please copy that to forum and I will provide you further steps.
hi roustam,
yes i have backup data . i tried to clear alt list . and run translator recovery again. but i get follwing error.
Regeneration translator.
clearing glist
completed
UNC ( 48 bit) error
fork direction ambiquty.
correct it manualy
LBA 85655454
clearing glist
completed
UNC ( 48 bit) error
correct it manualy
LBA 85655454
