ST3250823AS - Which ROM chip?
Gelkin.net
Postby Gelkin.net » 22.03.11, 14:19
I've received a customer case which has a broken Sata adaptor and a burnt component. Reading the manual I understand I need to remove the Serial Flash chip from this broken board and put it on a working board. Which chip exactly is it? I labeled them 1 and 2. Or is it both of them?
Here is a modified scan explaining the situation more clearly.
follow-up question. The donor PCB's I have are the same "part number" as the broken one. However the drives they come from are not identical. They are from drives ST3200826AS, the broken drive is ...823AS!!
Gelkin.net
Re: ST3250823AS - Which ROM chip?
Postby Gelkin.net » 22.03.11, 15:03
Feed back from Roustam is that the 2nd chip is the serial flash.
