Momentus 5400.6 - 0MB problem - solution don't work
DataStudio
Postby DataStudio » 11.03.11, 15:21
Today I've encountered following problem with Seagate Momentus 5400.6, after powering on it was recognized and DRD, DSC leds appeared.
After opening utility, the capacity was ( )MB, so I tried to use the solution, but without good result, You can see the attachment.
Tried also to read response from terminal, it showed only:
Rst 0x08M
After trying to regenerate translator, it failed, but terminal showed a few responses:
LED:000000CC FAddr:00237EC5
Would You please provide advices, how to solve this problem and what do You think the problem is related to?
Swapping the heads could solve the problem ?
Thanks for answers folks!
DataStudio
Re: Momentus 5400.6 - 0MB problem - solution don't work
Postby DataStudio » 14.03.11, 17:04
I've performed following steps described by clayron
source: http://forum.hddguru.com/seagate-st9500 ... tml#p99337
According to log below, would anybody tell me what shall I do next to solve the problem?
Code: Select all
Rst 0x08M
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00 00 A0 E1
            opts = 00000000
RW Err = 84150180
ASCII Diag mode
F3 T>/2
F3 2>Z
Spin Down Complete
Elapsed Time 0.140 msecs
F3 2>
ATA  15 Cmds
Ts(ms)     dT(ms)   Op Cnt  LBA
         0 99999999 00 0000 000000000000
         0        0 00 0000 000000000000
RW  32 Cmds
Ts(ms)     dT(ms)   xT(ms)  Type Option Mode  St EC       Info
4294967295 99999999        0 FF  FFFFFFFF FFFFFFFF FF EFFFFFFF
4294967295        0        0 FF  FFFFFFFF FFFFFFFF FF FFFFFFFF
       713      714    13943 2F  000000 000000 2 84150180 SPN_UP NORMAL
     14650    13937 99999999 2F  000000 000000 FF FFFFFFFF SPN_UP NORMAL
     14673       23        4 1B  000000 000000 1 00000080 MEM_DBG
     14677        4        0 03  000000 000000 1 00000080 RD_CHNL
     14678        1     2870 30  000000 000000 1 00000080 SPN_DN NORMAL
     90319    75641        0 27  000000 000000 1 00000080 SND_SRV 0501 0000 0000 0000 0000 0000 0000 0000 0001 012F 00D0
                                                          012F 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
     90320        1        0 27  000000 000000 1 00000080 SND_SRV 0106 0000 0000 0000 0000 0000 0000 0000 0001 012F 00D0
     90320        0        0 27  000000 000000 1 00000080 SND_SRV 0501 008F 0000 0000 0000 0000 0000 0000 0001 AD6F 00D0
                                                          AD6F 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
     90321        1        0 30  000000 000000 1 00000080 SPN_DN NORMAL U
Spin Up Complete
Elapsed Time 1.225 secs
F3 2>
ATA  15 Cmds
RW  32 Cmds
4294967295 99999999        0 FF  FFFFFFFF FFFFFFFF FF FFFFFFFF
    146539    56218     1226 2F  000000 000000 1 00000080 SPN_UP NORMAL
    147766     1227       19 00  002014 000000 1 00000080 SEEK USR TRK CH 000000.0 /T
F3 T>V4
Reassigned Sectors List
Original     New    log log   log     phy     phy
    LBA      PBA    cyl  hd  sctr zn  cyl hd  sctr     SFI
         Alt   Pending  Total    Alted  Total
       Entries Entries Entries    Alts   Alts
Head 0              0
Head 1              0
Total        0      0       0        0      0
Total Alt Removals:    0
Checksum = 0000
F3 T>
ATA  15 Cmds
RW  32 Cmds
    170941    23175       28 02  001121 000000 1 00000080 XFR RD SYS LBA B 00007E5D L 00000180 BO 000000 BES 003C000.0047FFF.003C000
    170970       29       14 02  001121 000000 1 00000080 XFR RD SYS LBA B 00007FDD L 00000100 BO 000000 BES 0048000.004FFFF.0048000
    170984       14        1 27  001121 000000 1 00000080 SND_SRV 516F 0000 0000 0000 0000 0000 0000 0000 0001 01FF 00D0
                                                          0000 0000 0001 CBA5 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
tec
Postby tec » 06.05.11, 10:25
Backup FW
Regenerate translator :-)
