Techno key error; unexpected error: Drive is not ready
asocla
Postby asocla » 05.03.11, 02:32
By programming the ROM disk WD3200AAJS-22L7A0 I have the wrong ROM.
Since then PC3000 gives me the error of the topic. how can I retrieve the mail and duly reprogramming?
Thanks Claudio
hassan
Re: Techno key error; unexpected error: Drive is not ready
Postby hassan » 05.03.11, 10:28
Unfortunately you can not rewrite a new Rom by PC-3000
You have to find another PCB
Igor
Postby Igor » 05.03.11, 13:03
It is Pinclite. Usually Rom is located in main chip on drives of this family.
So unfortunately if you get such error you can not do nothing.
If pcb has external rom chip (U12) you can unsolder it and write proper rom via external programmer.
hassan
Postby hassan » 05.03.11, 14:25
Hello Igor
If the PCB do not have external Rom chip can i plug a rom chip ?
I have 2 PCB belong to pinclite family wrong rom files was written so can i put external rom and repair the 2 pcb's
asocla
Postby asocla » 05.03.11, 16:21
In my opinion there should be some bridge plate to be done to reset the chip.
Because a mistake can happen, and when that happens we could go back without going to extreme cases like the replacement of the PCB or the chip desoldering.
