Seagate ST9500420AS
Monk
Seagate ST9500420AS
Postby Monk » 17.01.11, 11:45
The problem i'm having with this drive is that it stops reading after lba 233584. I have found reassigned sectors list empty, so I'm guessing someone else tried to recover the data before me. The drive was outsourced to me, so the client can't tell much info about what happened before.
After I activated the "show additional diag msg in terminal", I got this output.
Code: Select all
Rst 0x20M
(P) SATA Reset
RAW OFF
 PASS
RW: Error processing Performance Parameter File: 203C
Anyone else encountered this before?
Thanks in advance.
DE AD
dmarques
Re: Seagate ST9500420AS
Postby dmarques » 18.01.11, 10:04
I think someone deleted the Lists and made a translator regeneration.
Now it's much harder to get it, but I think it's still possible with a lot of manual labour.
