WD3200AVBS-63TAA0 PCB problem
hassan
Postby hassan » 11.01.11, 13:24
I have WD3200AVBS-63TAA0 the pcb no is 2061-701444-000
the PCB was burnt
I have the same PCB nimber 2061-701444 but my question is :
What is the Family of this drive?
Any on have Rom for xxTAxx family?
einstein9
Re: WD3200AVBS-63TAA0 PCB problem
Postby einstein9 » 11.01.11, 13:39
move the ROM from defected hdd pcb to working pcb and good luck
hassan
Postby hassan » 11.01.11, 13:48
This model have no rom chip
the rom in the CPU chip and it was burnt
einstein9
Postby einstein9 » 11.01.11, 14:29
sorry for the mistake ur right here i did not notice
BUT
my best guess is Caviar
can u post the image of pcb other side
just to make sure
hassan
Postby hassan » 11.01.11, 15:27
Thank you for the help
einstein9
Postby einstein9 » 16.01.11, 10:58
my best guess for this is the Spider here since this pcb can be used for many families
another suggestion if you have a backup resources for it, open module C5
you will find the family there
good luck
hassan
Postby hassan » 17.01.11, 09:46
Dear einstein9
Thank you for help but unfortunately i don't have any resource for the drive
dmarques
Postby dmarques » 18.01.11, 10:05
If you use safe mode, you can see family.
hassan
Postby hassan » 18.01.11, 10:46
Thank you datalabace
but the PCB was burnt so i can not run kernel mode
dmarques
Postby dmarques » 18.01.11, 15:47
Why do you want to know it's family?
hassan
Postby hassan » 24.01.11, 07:10
I want to write Rom from the same family to get access to SA and recover the Rom of HDD
The i can get the data
einstein9
Postby einstein9 » 24.01.11, 14:25
hassan, u dont need to know or select family to write the rom
pick any, and write
this will not effect anything since ur writing rom
good luck
