WD5000BMVV problem
kyriakosxn
WD5000BMVV problem
Postby kyriakosxn » 10.01.11, 17:02
I have 5 HDDs WD5000BMVV MARVELL USB MARINER 2.5"
All 5 HDDs give me the same error. They cannot access SA.
Code: Select all
Techno mode key
SA SPT.................................. : 500
ROM version............................. : 14.E8P
ROM generation.......................... : 14.E8P
Link table version...................... : 05.D0.
Head map................................ : 0,1,2,3
ROM Firmware version.................... : 001400E8
Service area:
SA dir reading.......................... : Drive is not ready
SA Firmware version..................... : Module part reading error unexpected error: ATA Command sending error (method 3); Win32 Error.  Code: 121.
The semaphore timeout period has expired
Features in not avalabled
Can anyone tell me if this means head problem for all HDDs?
Thanks.
dmarques
Re: WD5000BMVV problem
Postby dmarques » 11.01.11, 11:04
You should indicate better some issues.
- What happened to the drives first of all
- Do you hear any clicking sounds and then drive spins off?
- Have you tried to read each head individually?
- Have you tried hotswap to access SA?
kyriakosxn
Postby kyriakosxn » 11.01.11, 16:23
Thanks for your reply.
All drives start clicking when they try to access SA.
I didn't try Hot Swap because i dont have any functional HDD.
dmarques
Postby dmarques » 12.01.11, 11:56
Still some answers to reply.
kyriakosxn
Postby kyriakosxn » 12.01.11, 15:27
Yes all drives stop spinning after some clicks.
I also tried through ROM HEAD EDITING enable only one head at a time, but still no result.
dmarques
Postby dmarques » 12.01.11, 16:32
So there's only 2 chances.
- Hotswap
- Swap heads
But I think hotswap will not allow you to read anything.
