problem of read sectors
digital
Postby digital » 04.11.10, 18:25
I Have received several Seagate Hard Drives that is possible to clone several million of sectors without errors. However later to clone 30%, 40% or 50% of sectors don't is possible to clone more. In another words, part of sectors is cloned without errors and part of sectors don't is cloned, no read, get errors in all sectors. What is this problem? Is firwmare? translate? or what?
Re: problem of read sectors
Postby AJ2008 » 05.11.10, 12:02
I guess is possible you have some platter shift, like in eccentricity. Was disk dropped? Probably inside external case?
digital
Postby digital » 05.11.10, 20:00
Hi, thanks for the reply. Did not change the platter, the disk is still sealed, also did not fall.
digital
Postby digital » 05.11.10, 22:57
AJ2008 wrote:I guess is possible you have some platter shift, like in eccentricity. Was disk dropped? Probably inside external case?
-BR-
Postby -BR- » 06.11.10, 18:50
What family / model(s) are you speaking about?
Any terminal output on the errors?
digital
Postby digital » 08.11.10, 12:53
-BR- wrote:What family / model(s) are you speaking about?
The model is ST3750330AS - 7200.11 - FW SD15, clone halfway and then gives the screen black and yellow
Postby AJ2008 » 08.11.10, 15:29
Did this case have 0 LBA/LED CC error?
also, did you clear glist on this case?
digital
Postby digital » 11.11.10, 13:47
AJ2008 wrote:Did this case have 0 LBA/LED CC error?
No led cc, no clone
Postby AJ2008 » 11.11.10, 14:29
I tihnk is very likely that somebody did try firmware repair previously on this case.
