Hitachi HDT721010SLA360 stays BSY
rcz
Postby rcz » 28.10.10, 09:10
Here is a Hitachi HDT721010SLA360 (1 Tb).
Drive seems to initialize but stays BSY. I tried to change PCB in importing NV-RAM, and to change head, drive stays BSY.
When I change PCB only, drive goes to DRD-DSC but "Err ABR" appeared (as NV-RAM is not original one), but I can access to modules who are all good except for SRST and NVRC.
What can be done for thic case ?
admin
Re: Hitachi HDT721010SLA360 stays BSY
Postby admin » 03.11.10, 14:52
It seems that original NV-RAM has corruptions so the drive cannot initialize itself, there is NV-RAM recovery from NVRC module required.
We have figured out that SLA family has different offset of NVRC module.
This mistake is corrected in PC-3000 source code, will be fixed in the next version of software.
In the current SW version you can save the NVRC module manually.
It consists of 4 sectors by the offset 0xFE0602FC.
Here is an example of NV-RAM recovery from NVRC module on SLA family:
1. Save 8 bytes from USAG module by the offset 4h.
NVRC has a factory version so you have to change it to the USAG's version.
2. Open service information objects item and dump the NVRC module by its real offset, it's size is 2kb (4h sectors)
3. Select and copy all bytes of dumped data (CTRL+A, CTRL+C)
4. Open again service information objects item and dump the NV-RAM
5. Select and paste there data you've copied on step 3 (CTRL+A, CTRL+V), change 8 bytes by offset 4h to the data from the step 1 (in my example 5354364F4133374Dh ---> 5354364E41333142h), then click "write to hdd".
6. Restart the power and you should get access to user data.
ACE Laboratory
Technical support & development,
Alexander (Sasha) Sheremetov
ts2@acelab.ru
rcz
Postby rcz » 04.11.10, 09:19
Thanks Sasha, but it doesn't works, drive stays BSY, as with original NV-RAM.
One head of the donor seems to be very slow now, I think one head on the patient is bad too...
I think there is no way to initialize this disk to read with heads who are still good... If only hotswap could have worked with Hitachi's...
Postby AJ2008 » 04.11.10, 13:50
rcz wrote:Thanks Sasha, but it doesn't works, drive stays BSY, as with original NV-RAM.
Hotswap is possible in some sitations in Hitachi
rcz
Postby rcz » 04.11.10, 14:05
AJ2008 wrote:in some sitations
:roll: Now you have to tell me more :mrgreen:
Postby AJ2008 » 04.11.10, 14:08
Do you use msn/skype? :?:
rcz
Postby rcz » 04.11.10, 15:28
Yep -> rcztech
rcz
Postby rcz » 08.11.10, 09:04
Solved. To close 8)
slack
Postby slack » 17.08.11, 15:03
I have one similar problem with one HDT721010SLA360 which remain BSY, possible head 0 weak, with head swap the result is the same still remain BSY.
If i unscrew the PCB it become DRD,DSC and after that i screw back and i continue in utility and i can read all the modules.
There are few modules which i can't read from head 0 but i can read all of them from head 1.
My final conclusion is that i need HOT SWAP, can somebody tell me how to try it?
Thanks.
hassan
Postby hassan » 17.08.11, 16:20
you can find the answer in
Bad sectors in service area solution
viewtopic.php?f=30&t=7186
slack
Postby slack » 19.08.11, 12:49
hassan wrote:Hello
I used before this method but is not working in this case case
slack
Postby slack » 19.08.11, 12:55
The strange thing in my case is that i can read all SA but there is something wrong between SA and NVRAM.
I attached the SA Structure test
Start SA checking.rar
(2.62 KiB) Downloaded 650 times
