Toshiba 2.5" SATA Serial Adapter
dataLAB
Postby dataLAB » 11.10.10, 03:35
We have made a very good adapter for PC3000 using an old CDROM Audio Cable.
Using a standard CDROM Audio Cable type with small 4-pin plug on one end to fit to PC motherboard socket - we found this fits the Toshiba serial pin-out perfectly.
The other end of the cable we soldered onto a spare old PC-Seagate PC3000 Adapter. Alternatively the wires could be swapped around to allow direct plug into PC USB TERMINAL adapter (instead of ribbon cable)
:idea:
Gelkin.net
Re: Toshiba 2.5" SATA Serial Adapter
Postby Gelkin.net » 13.10.10, 13:20
dataLAB wrote:We have made a very good adapter for PC3000 using an old CDROM Audio Cable.
:idea:
Could you post a link to an image? To make the picture clear in my mind ;) Thanks
tea
Postby tea » 02.05.11, 19:42
yes ! need some image . please
Return to “Toshiba native”
