quantom d540x-4k ldr load to hdd
Moderators: Nick_TS, Filipp_TS
mojimorady
Postby mojimorady » 27.09.10, 10:32
hi guru
i have a quantom D540X-4K which needs loader to start up .
does quantom hdds need to be in safe mode for downloadig firmware to them ?
how is the safe mode jumper ?
please address me some manual on quantom .
regards
moji
Mojtaba Morady
Data Recovery Expert
Data Recovery Eng. at CSSI
Re: quantom d540x-4k ldr load to hdd
Postby AJ2008 » 27.09.10, 12:03
You need to access through Terminal with PC-Quantum adaptor.
Then you can load LDR.
What is the problem you have?
mojimorady
Postby mojimorady » 28.09.10, 16:25
hi AJ2008
tnx for response
actually the hdd is not detected by pc3000 , but the spindle motor spins ( the problem is like
seagate barracuda 7200.10 OK? )
now i think with loading firmware to hdd it will be ok
do you have any idea ?
mojimorady@msn.com
we also can share more info throuh my email address
regards
moji
Mojtaba Morady
Return to “Quantum”
