Hi All,
Im not so experienced with Fujitsu drives, any help would be appreciated. This drive appears to be locked, but the unlock failures. I believe most likely due to the errors with read the password modules 010C and 010D . Drive doesn't make any suspicious noises, and comes ready with Model/Serial data read ok. Log Below
ATTENTION! Security-locked HDD!
Selected family......................... : MHV2xxxAT/AH
Selected model.......................... : MHV2100AT
Model by HDD ID......................... : FUJITSU MHV2100BH
Reading module table from SA...
Module table is loaded
Loading : HS, head map module......................................... : Ok
Loading : PL, single sector defect list and zone allocation table modu : Ok
Test : SA structure test
LOADING MODULES
Module 0104........................................................... : Ok
Module 0120........................................................... : Ok
Module 0106........................................................... : Ok
Module 0122........................................................... : Ok
Module 01E1........................................................... : Ok
Module 01B4........................................................... : Ok
Module 01B0........................................................... : Ok
Module 01B1........................................................... : Ok
Module 01B2........................................................... : Ok
Module 01B3........................................................... : Ok
Can`t read module 013D from HDD
Module 013D........................................................... : Error
Can`t read module 013E from HDD
Module 013E........................................................... : Error
Can`t read module 013F from HDD
Module 013F........................................................... : Error
Can`t read module 0140 from HDD
Module 0140........................................................... : Error
Can`t read module 015A from HDD
Module 015A........................................................... : Error
Can`t read module 015B from HDD
Module 015B........................................................... : Error
Module 0101........................................................... : Ok
Module 01E8........................................................... : Ok
Module 0107........................................................... : Ok
Module 01E2........................................................... : Ok
Module 0108........................................................... : Ok
Can`t read module 010C from HDD
Module 010C........................................................... : Error
Can`t read module 010D from HDD
Module 010D........................................................... : Error
Module 010A........................................................... : Ok
Module 012D........................................................... : Ok
Module 012B........................................................... : Ok
Module 012A........................................................... : Ok
Module 0109........................................................... : Ok
Module 0131........................................................... : Ok
Module 0127........................................................... : Ok
Module 0132........................................................... : Ok
Module 0128........................................................... : Ok
Module 0145........................................................... : Ok
Module 0170........................................................... : Ok
Module 0129........................................................... : Ok
Module 0137........................................................... : Ok
Module 01E9........................................................... : Ok
Module 01EA........................................................... : Ok
Can`t read module 0150 from HDD
Module 0150........................................................... : Error
Can`t read module 0155 from HDD
Module 0155........................................................... : Error
Can`t read module 0154 from HDD
Module 0154........................................................... : Error
Module 0151........................................................... : Ok
Module 0152........................................................... : Ok
Can`t read module 0157 from HDD
Module 0157........................................................... : Error
Module 0102........................................................... : Ok
Module 010B........................................................... : Ok
Module 0105........................................................... : Ok
Module 010E........................................................... : Ok
Module 0130........................................................... : Ok
Module 0135........................................................... : Ok
Module 0136........................................................... : Ok
Module 012E........................................................... : Ok
Module 0141........................................................... : Ok
Module 0142........................................................... : Ok
Module 0103........................................................... : Ok
Module 01E3........................................................... : Ok
Module 01E4........................................................... : Ok
Module 01E5........................................................... : Ok
Module 01E6........................................................... : Ok
Module 01E7........................................................... : Ok
Module 0123........................................................... : Ok
Drive not ready
Module 01F3........................................................... : Error
Drive not ready
Module 01D0........................................................... : Error
Drive not ready
Module 01D1........................................................... : Error
Module 0156........................................................... : Ok
Module 0110........................................................... : Ok
Module 0111........................................................... : Ok
Module 0112........................................................... : Ok
Module 0113........................................................... : Ok
Module 0114........................................................... : Ok
Module 0115........................................................... : Ok
Module 0116........................................................... : Ok
Module 0117........................................................... : Ok
Module 0118........................................................... : Ok
Module 0119........................................................... : Ok
Module 011E........................................................... : Ok
Drive not ready
Module 01F4........................................................... : Error
Drive not ready
Module 01F5........................................................... : Error
Drive not ready
Module 01F6........................................................... : Error
Drive not ready
Module 0166........................................................... : Error
Drive not ready
Module 0167........................................................... : Error
Drive not ready
Module 0168........................................................... : Error
Module 011C........................................................... : Ok
Module 011D........................................................... : Ok
Module 011F........................................................... : Ok
Module 0121........................................................... : Ok
Module 0160........................................................... : Ok
Module 0161........................................................... : Ok
Module 0162........................................................... : Ok
Module 0163........................................................... : Ok
Module 0164........................................................... : Ok
Module 0165........................................................... : Ok
Module 01A1........................................................... : Ok
Module 01A2........................................................... : Ok
Module 0180........................................................... : Ok
Module 01C0........................................................... : Ok
Module 0201........................................................... : Ok
Module 0204........................................................... : Ok
Module 0206........................................................... : Ok
Module 0207........................................................... : Ok
Module 0208........................................................... : Ok
Can`t read module 020C from HDD
Module 020C........................................................... : Error
Can`t read module 020D from HDD
Module 020D........................................................... : Error
Module 0220........................................................... : Ok
Module 0222........................................................... : Ok
Module 0227........................................................... : Ok
Module 022B........................................................... : Ok
Module 0237........................................................... : Ok
Module 0241........................................................... : Ok
Module 0242........................................................... : Ok
Can`t read module 0255 from HDD
Module 0255........................................................... : Error
Module 0256........................................................... : Ok
Module 02B0........................................................... : Ok
Module 02B1........................................................... : Ok
Module 02B2........................................................... : Ok
Module 02B3........................................................... : Ok
Module 02B4........................................................... : Ok
Module 02E0........................................................... : Ok
Module 02E1........................................................... : Ok
Module 02E2........................................................... : Ok
Module 02E5........................................................... : Ok
Module 02E6........................................................... : Ok
Module 02E7........................................................... : Ok
Module 02E8........................................................... : Ok
Module 02EA........................................................... : Ok
MHV2100BH
