WD3200BEKT
sempre
WD3200BEKT
Postby sempre » 25.08.10, 16:01
Hi to all!
Four heads, is one bad (0-good, 1-good, 2-good, 3-BAD)
How do I get the most files without changing the heads?
Thanks!
nothing is impossible!
Re: WD3200BEKT
Postby AJ2008 » 25.08.10, 16:32
Does HDD calibrate and show ID but H3 is inaccessible, or does spindle stop and no ID is possible?
In both situations there is possibility for access to surfaces 0,1,2 but further info on the symptoms will help
sempre
Re: WD3200BEKT
Postby sempre » 25.08.10, 17:20
AJ2008 wrote:Does HDD calibrate and show ID but H3 is inaccessible, or does spindle stop and no ID is possible?
Yes, ready id hdd.
Started clone in DE UDMA (head 3 disable)
houman_2h
Re: WD3200BEKT
Postby houman_2h » 26.08.11, 15:07
sempre wrote:Hi to all!
Thanks!
it is easy . in DE . building map menu and then disable head 3
good luck
