*** Break at 0x006B [from Trap]
sempre
Postby sempre » 12.08.10, 22:23
Hi to all! :mrgreen:
HD082GJ
ENG>SRV>
SvoTbl Loaded
CL DB06 CM DB4F SL ECBC SM ECCB
BD
FdtTbl Loaded
Compare. 0001
hd0000: 009C
006B: 003E
DBG>DBG> SPW 1.5G LinkOk!
FlashCheckSum Ok!
00017FFF 0000 E94E5V: 04940
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0004
DAC: 7086
SK C: 000195B3
ENG>SRV>
SvoTbl Loaded
CL DB06 CM DB1D SL ECBC SM ECAA
BD
FdtTbl Loaded
Compare. 0001
hd0000: 009C
006B: 003E
nothing is impossible!
N.C.
Re: *** Break at 0x006B [from Trap]
Postby N.C. » 03.09.10, 13:28
sempre wrote:Hi to all! :mrgreen:
HD082GJ
ENG>SRV>
SvoTbl Loaded
BD
FdtTbl Loaded
Compare. 0001
hd0000: 009C
006B: 003E
FlashCheckSum Ok!
SpnOk
spd: 0000 0000 0000
H: +00000
ADC: 0004
DAC: 7086
SK C: 000195B3
ENG>SRV>
SvoTbl Loaded
BD
FdtTbl Loaded
Compare. 0001
hd0000: 009C
006B: 003E
This is alternative PCB (ROM) or the SA have a problem wich triggers this bug.
you should try to repair SA with the burn code (with cancelled test by soft reset) or with hotswap.
Both have some risk. (Burn code can destroy SA and/or user data, hotswap can damage the tracks with missmatching adaptives.)
Janos
N.C.
Postby N.C. » 03.09.10, 13:30
OR! Better idea to use different version PCB wich can refuse to start the SA. :)
