WD2500JS-60NCB1 sounds well but not recognized
rcz
Postby rcz » 08.07.10, 13:34
Here is a WD2500JS-60NCB1, not knocking, sounds that it initiliazes, but recognized in "Marvell".
14311 Utility.jpg (167.83 KiB) Viewed 3688 times
I know that PCB has been removed (screw weren't enough screwed) but I don't know if this is the native PCB. Hdd falls down last year, was given to someone but my customer don't know what he has done, she says probably nothing. According to her, the PCB is the native.
Hdd Resource Back Up is done.
I don't know where to begin now. I don't want to do something wrong as it's maybe wrong ROM.
I have a donor which has exactly the same label (same model, same manufacture day, same DCM).
Here is Structure Test :
Id:Copy: Importance:Cyl :Head:Sector:Size:Read : Hdr : CS : CS Value: Date : Vers.: Desription
01: 0 : B : -1: 0: 0: 2:Yes : Ok : Ok : 70 :03-09-06:109B? :Modules directory
01: 1 : B : -1: 1: 0: 2:Yes : Ok : Ok : 70 :03-09-06:109B? :Modules directory
26: 0 : : -1: 0: 6: 129:Yes : Ok : Ok : 1B :24-05-06:109B? :
26: 1 : : -1: 1: 6: 129:Yes : Ok : Ok : 1B :24-05-06:109B? :
1C: 0 : B : -1: 0: 139: 27:Yes : Ok : Ok : 37 :24-05-06:109BE :Loaded part of microprogram code
1C: 1 : B : -1: 1: 139: 27:Yes : Ok : Ok : 37 :24-05-06:109BE :Loaded part of microprogram code
42: 0 : As : -1: 0: 176: 19:Yes : Ok : Ok : DE :24-05-06:109B? :Adaptive data
42: 1 : As : -1: 1: 176: 19:Yes : Ok : Ok : DE :24-05-06:109B? :Adaptive data
34: 0 : C : -1: 0: 199: 12:Yes : Ok : Ok : 98 :24-05-06:1500? :G-List (Grown defect list)
34: 1 : C : -1: 1: 199: 12:Yes : Ok : Ok : 98 :24-05-06:1500? :G-List (Grown defect list)
29: 0 : B : -1: 0: 215: 5:Yes : Ok : Ok : 7F :24-05-06:109B? :Loaded part of microprogram code
29: 1 : B : -1: 1: 215: 5:Yes : Ok : Ok : 7F :24-05-06:109B? :Loaded part of microprogram code
52: 0 : As : -1: 0: 224: 2:Yes : Ok : Ok : 49 :24-05-06:109B? :Parameters table 3
52: 1 : As : -1: 1: 224: 2:Yes : Ok : Ok : 49 :24-05-06:109B? :Parameters table 3
35: 0 : Dd : -2: 0: 0: 1:Yes : Ok : Ok : A2 :13-10-02:6271? :SA Defects
35: 1 : Dd : -2: 1: 0: 1:Yes : Ok : Ok : A2 :13-10-02:6271? :SA Defects
02: 0 : B : -2: 0: 5: 2:Yes : Ok : Ok : 78 :24-05-06:0800? :Configuration (HDD ID)
02: 1 : B : -2: 1: 5: 2:Yes : Ok : Ok : 78 :24-05-06:0800? :Configuration (HDD ID)
33: 0 : Dd : -2: 0: 11: 510:Yes : Ok : Ok : A9 :24-05-06:1500? :P-List (Primary defect list)
33: 1 : Dd : -2: 1: 11: 510:Yes : Ok : Ok : A9 :24-05-06:1500? :P-List (Primary defect list)
1B: 0 : B : -2: 0: 525: 100:Yes : Ok : Ok : E9 :24-05-06:109BE :Loaded part of microprogram code
1B: 1 : B : -2: 1: 525: 100:Yes : Ok : Ok : E9 :24-05-06:109BE :Loaded part of microprogram code
19: 0 : B : -2: 0: 635: 25:Yes : Ok : Ok : A5 :24-05-06:109BE :Loaded part of microprogram code
19: 1 : B : -2: 1: 635: 25:Yes : Ok : Ok : A5 :24-05-06:109BE :Loaded part of microprogram code
2A: 0 : B : -2: 0: 670: 5:Yes : Ok : Ok : FE :24-05-06:109B? :Loaded part of microprogram code
2A: 1 : B : -2: 1: 670: 5:Yes : Ok : Ok : FE :24-05-06:109B? :Loaded part of microprogram code
2D: 0 : Dr : -3: 0: 0: 283:No : : : : : :Debug Log
2D: 1 : Dr : -3: 1: 0: 283:No : : : : : :Debug Log
22: 0 : B : -3: 0: 293: 64:No : : : : : :S.M.A.R.T.
22: 1 : B : -3: 1: 293: 64:No : : : : : :S.M.A.R.T.
1E: 0 : B : -3: 0: 361: 23:No : : : : : :Loaded part of microprogram code
1E: 1 : B : -3: 1: 361: 23:No : : : : : :Loaded part of microprogram code
41: 0 : As : -3: 0: 394: 19:No : : : : : :Adaptive data
41: 1 : As : -3: 1: 394: 19:No : : : : : :Adaptive data
04: 0 : B : -3: 0: 417: 9:No : : : : : :Family models configuration (Main)
04: 1 : B : -3: 1: 417: 9:No : : : : : :Family models configuration (Main)
0C: 0 : B : -3: 0: 430: 4:No : : : : : :Models table
0C: 1 : B : -3: 1: 430: 4:No : : : : : :Models table
53: 0 : As : -3: 0: 438: 2:No : : : : : :Parameters table 4
53: 1 : As : -3: 1: 438: 2:No : : : : : :Parameters table 4
11: 0 : B : -8: 0: 0: 282:No : : : : : :Loaded part of microprogram code
11: 1 : B : -8: 1: 0: 282:No : : : : : :Loaded part of microprogram code
21: 0 : B : -8: 0: 292: 64:No : : : : : :S.M.A.R.T.
21: 1 : B : -8: 1: 292: 64:No : : : : : :S.M.A.R.T.
61: 0 : B : -8: 0: 360: 27:No : : : : : :Loaded part of microprogram code
61: 1 : B : -8: 1: 360: 27:No : : : : : :Loaded part of microprogram code
4C: 0 : B : -8: 0: 391: 13:No : : : : : :Loaded part of microprogram code
4C: 1 : B : -8: 1: 391: 13:No : : : : : :Loaded part of microprogram code
06: 0 : B : -8: 0: 414: 9:No : : : : : :Family models configuration (Alt2)
06: 1 : B : -8: 1: 414: 9:No : : : : : :Family models configuration (Alt2)
4A: 0 : As : -8: 0: 427: 4:No : : : : : :Adaptive data
4A: 1 : As : -8: 1: 427: 4:No : : : : : :Adaptive data
36: 0 : Ad : -8: 0: 435: 2:No : : : : : :T-List Module
36: 1 : Ad : -8: 1: 435: 2:No : : : : : :T-List Module
31: 0 : Ad : -9: 0: 0: 263:Yes : Ok : Ok : A0 :20-08-49:1500? :Translator
31: 1 : Ad : -9: 1: 0: 263:Yes : Ok : Ok : A0 :20-08-49:1500? :Translator
23: 0 : B : -9: 0: 273: 64:Yes : Ok : Ok : 5F :24-05-06:2107? :S.M.A.R.T. Log (reserved)
23: 1 : B : -9: 1: 273: 64:Yes : Ok : Ok : 5F :24-05-06:2107? :S.M.A.R.T. Log (reserved)
15: 0 : B : -9: 0: 341: 14:Yes : Ok : Ok : ED :24-05-06:109BE :Loaded part of microprogram code
15: 1 : B : -9: 1: 341: 14:Yes : Ok : Ok : ED :24-05-06:109BE :Loaded part of microprogram code
40: 0 : As : -9: 0: 365: 19:Yes : Ok : Ok : 94 :24-05-06:109B? :Adaptive data
40: 1 : As : -9: 1: 365: 19:Yes : Ok : Ok : 94 :24-05-06:109B? :Adaptive data
07: 0 : B : -9: 0: 388: 9:Yes : Ok : Ok : F5 :24-05-06:0200? :Family models configuration (Alt3)
07: 1 : B : -9: 1: 388: 9:Yes : Ok : Ok : F5 :24-05-06:0200? :Family models configuration (Alt3)
49: 0 : As : -9: 0: 401: 2:Yes : Ok : Ok : 87 :24-05-06:109B? :Adaptive data
49: 1 : As : -9: 1: 401: 2:Yes : Ok : Ok : 87 :24-05-06:109B? :Adaptive data
37: 0 : Dr : -9: 0: 407: 1:Yes : Ok : Ok : 7C :24-05-06:0100? :Gain Call Data Module
37: 1 : Dr : -9: 1: 407: 1:Yes : Ok : Ok : 7C :24-05-06:0100? :Gain Call Data Module
25: 0 : : -10: 0: 0: 257:No : : : : : :
25: 1 : : -10: 1: 0: 257:No : : : : : :
24: 0 : B : -10: 0: 261: 64:Yes : Ok : Ok : C6 :24-05-06:2107? :S.M.A.R.T. Log (reserved)
24: 1 : B : -10: 1: 261: 64:Yes : Ok : Ok : C6 :24-05-06:2107? :S.M.A.R.T. Log (reserved)
32: 0 : Ad : -10: 0: 329: 20:Yes : Ok : Ok : EC :20-08-49:1500? :Relo Bad Block Module
32: 1 : Ad : -10: 1: 329: 20:Yes : Ok : Ok : EC :20-08-49:1500? :Relo Bad Block Module
39: 0 : B : -10: 0: 353: 17:Yes : Ok : Ok : 78 :24-05-06:109B? :Loaded part of microprogram code
39: 1 : B : -10: 1: 353: 17:Yes : Ok : Ok : 78 :24-05-06:109B? :Loaded part of microprogram code
05: 0 : B : -10: 0: 374: 9:Yes : Ok : Ok : 7F :24-05-06:0200? :Family models configuration (Alt1)
05: 1 : B : -10: 1: 374: 9:Yes : Ok : Ok : 7F :24-05-06:0200? :Family models configuration (Alt1)
50: 0 : As : -10: 0: 387: 2:Yes : Ok : Ok : 23 :24-05-06:109B? :Parameters table 1
50: 1 : As : -10: 1: 387: 2:Yes : Ok : Ok : 23 :24-05-06:109B? :Parameters table 1
62: 0 : : -10: 0: 393: 1:Yes : Ok : Ok : 5F :24-05-06:109B? :
62: 1 : : -10: 1: 393: 1:Yes : Ok : Ok : 5F :24-05-06:109B? :
38: 0 : B : -11: 0: 0: 257:Yes : Ok : Ok : 88 :24-05-06:109B? :Loaded part of microprogram code
38: 1 : B : -11: 1: 0: 257:Yes : Ok : Ok : 88 :24-05-06:109B? :Loaded part of microprogram code
17: 0 : B : -11: 0: 261: 30:Yes : Ok : Ok : 99 :24-05-06:109BE :Loaded part of microprogram code
17: 1 : B : -11: 1: 261: 30:Yes : Ok : Ok : 99 :24-05-06:109BE :Loaded part of microprogram code
43: 0 : As : -11: 0: 301: 19:Yes : Ok : Ok : 81 :24-05-06:109B? :Adaptive data
43: 1 : As : -11: 1: 301: 19:Yes : Ok : Ok : 81 :24-05-06:109B? :Adaptive data
28: 0 : Dr : -11: 0: 324: 16:Yes : Ok : Ok : ED :02-09-06:0300? :Factory Self Test script
28: 1 : Dr : -11: 1: 324: 16:Yes : Ok : Ok : ED :02-09-06:0300? :Factory Self Test script
2F: 0 : B : -11: 0: 344: 5:Yes : Ok : Ok : 6A :24-05-06:109BE :Loaded part of microprogram code
2F: 1 : B : -11: 1: 344: 5:Yes : Ok : Ok : 6A :24-05-06:109BE :Loaded part of microprogram code
51: 0 : As : -11: 0: 353: 2:Yes : Ok : Ok : 12 :24-05-06:109B? :Parameters table 2
51: 1 : As : -11: 1: 353: 2:Yes : Ok : Ok : 12 :24-05-06:109B? :Parameters table 2
C4: 0 : Dr : -3: 0: 444: 96:No : : : : : :Calibrations module
C4: 1 : Dr : -3: 1: 444: 96:No : : : : : :Calibrations module
C5: 0 : Dr : -1: 0: 230: 3:Yes : Ok : Ok : 2A :25-05-06:R.05? :Calibration script (DCM)
C5: 1 : Dr : -1: 1: 230: 3:Yes : Ok : Ok : 2A :25-05-06:R.05? :Calibration script (DCM)
CC: 0 : Dr : -1: 0: 233: 6:Yes : Ok : Ok : FB :25-05-06:R.9U? :Calibrations module
CC: 1 : Dr : -1: 1: 233: 6:Yes : Ok : Ok : FB :25-05-06:R.9U? :Calibrations module
CA: 0 : Dr : -1: 0: 239: 6:Yes : Ok : Ok : A5 :25-05-06:R.9U? :Calibrations module
CA: 1 : Dr : -1: 1: 239: 6:Yes : Ok : Ok : A5 :25-05-06:R.9U? :Calibrations module
CB: 0 : Dr : -3: 0: 540: 6:Yes : Ok : Ok : 12 :25-05-06:R.9U? :Calibrations module
CB: 1 : Dr : -3: 1: 540: 6:Yes : Ok : Ok : 12 :25-05-06:R.9U? :Calibrations module
CD: 0 : Dr : -3: 0: 546: 6:Yes : Ok : Ok : 4D :25-05-06:R.9U? :Calibrations module
CD: 1 : Dr : -3: 1: 546: 6:Yes : Ok : Ok : 4D :25-05-06:R.9U? :Calibrations module
CF: 0 : Dr : -3: 0: 552: 6:Yes : Ok : Ok : BA :25-05-06:R.9U? :Calibrations module
CF: 1 : Dr : -3: 1: 552: 6:Yes : Ok : Ok : BA :25-05-06:R.9U? :Calibrations module
CE: 0 : Dr : -3: 0: 558: 6:Yes : Ok : Ok : 63 :25-05-06:R.9U? :Calibrations module
CE: 1 : Dr : -3: 1: 558: 6:Yes : Ok : Ok : 63 :25-05-06:R.9U? :Calibrations module
91: 0 : Dr : -1: 0: 245: 1:Yes : Ok : Ok : FD :25-05-06:R.9U? :Calibrations module
91: 1 : Dr : -1: 1: 245: 1:Yes : Ok : Ok : FD :25-05-06:R.9U? :Calibrations module
92: 0 : Dr : -1: 0: 246: 1:Yes : Ok : Ok : FC :25-05-06:R.9U? :Calibrations module
92: 1 : Dr : -1: 1: 246: 1:Yes : Ok : Ok : FC :25-05-06:R.9U? :Calibrations module
93: 0 : Dr : -3: 0: 564: 6:Yes : Ok : Ok : F6 :25-05-06:R.9U? :Calibrations module
93: 1 : Dr : -3: 1: 564: 6:Yes : Ok : Ok : F6 :25-05-06:R.9U? :Calibrations module
C1: 0 : Dr : -1: 0: 247: 1:Yes : Ok : Ok : DF :25-05-06:R.9U? :Calibrations module
C1: 1 : Dr : -1: 1: 247: 1:Yes : Ok : Ok : DF :25-05-06:R.9U? :Calibrations module
C2: 0 : Dr : -1: 0: 248: 2:Yes : Ok : Ok : CC :25-05-06:R.9U? :Calibrations module
C2: 1 : Dr : -1: 1: 248: 2:Yes : Ok : Ok : CC :25-05-06:R.9U? :Calibrations module
C7: 0 : Dr : -2: 0: 679: 1:Yes : Ok : Ok : C7 :25-05-06:R.9U? :Calibrations module
C7: 1 : Dr : -2: 1: 679: 1:Yes : Ok : Ok : C7 :25-05-06:R.9U? :Calibrations module
9E: 0 : Dr : -3: 0: 570: 3:Yes : Ok : Ok : EE :25-05-06:R.9U? :Calibrations module
9E: 1 : Dr : -3: 1: 570: 3:Yes : Ok : Ok : EE :25-05-06:R.9U? :Calibrations module
B1: 0 : : -3: 0: 573: 5:Yes : Ok : Ok : 1C :25-05-06:0118? :
B1: 1 : : -3: 1: 573: 5:Yes : Ok : Ok : 1C :25-05-06:0118? :
E0: 0 : Dr : -6: 0: 0: 510:Yes : Ok : Ok : 46 :25-05-06:6271? :Factory Self Test defects log
E0: 1 : Dr : -6: 1: 0: 510:Yes : Ok : Ok : 46 :25-05-06:6271? :Factory Self Test defects log
E8: 0 : Dr : -7: 0: 0: 469:Yes : Ok : Ok : 81 :25-05-06:6271? :Factory Self Test head 0 defects log
E8: 1 : Dr : -7: 1: 0: 469:Yes : Ok : Ok : 81 :25-05-06:6271? :Factory Self Test head 0 defects log
FE: 0 : Dr : -9: 0: 412: 128:Yes : Ok : Ok : 4E :25-05-06:6271? :Factory Self Test module
FE: 1 : Dr : -9: 1: 412: 128:Yes : Ok : Ok : 4E :25-05-06:6271? :Factory Self Test module
B6: 0 : Dr : -3: 0: 578: 90:No : : : : : :Factory Self Test module
B6: 1 : Dr : -3: 1: 578: 90:No : : : : : :Factory Self Test module
B7: 0 : Dr : -3: 0: 668: 9:No : : : : : :Test Clamp Data
B7: 1 : Dr : -3: 1: 668: 9:No : : : : : :Test Clamp Data
D5: 0 : Dr : -8: 0: 441: 117:No : : : : : :Factory Self Test module
D5: 1 : Dr : -8: 1: 441: 117:No : : : : : :Factory Self Test module
DA: 0 : Dr : -10: 0: 395: 111:No : : : : : :Factory Self Test module
DA: 1 : Dr : -10: 1: 395: 111:No : : : : : :Factory Self Test module
DB: 0 : Dr : -11: 0: 359: 93:Yes : Ok : Ok : 11 :25-05-06:6271? :Factory Self Test module
DB: 1 : Dr : -11: 1: 359: 93:Yes : Ok : Ok : 11 :25-05-06:6271? :Factory Self Test module
DF: 0 : Dr : -12: 0: 0: 112:Yes : Ok : Ok : 61 :25-05-06:6271? :Factory Self Test module
DF: 1 : Dr : -12: 1: 0: 112:Yes : Ok : Ok : 61 :25-05-06:6271? :Factory Self Test module
DD: 0 : Dr : -7: 0: 469: 86:Yes : Ok : Ok : 02 :25-05-06:6271? :Factory Self Test module
DD: 1 : Dr : -7: 1: 469: 86:Yes : Ok : Ok : 02 :25-05-06:6271? :Factory Self Test module
D6: 0 : Dr : -11: 0: 452: 91:Yes : Ok : Ok : F9 :25-05-06:6271? :Factory Self Test module
D6: 1 : Dr : -11: 1: 452: 91:Yes : Ok : Ok : F9 :25-05-06:6271? :Factory Self Test module
D7: 0 : Dr : -12: 0: 112: 91:Yes : Ok : Ok : 10 :25-05-06:6271? :Factory Self Test module
D7: 1 : Dr : -12: 1: 112: 91:Yes : Ok : Ok : 10 :25-05-06:6271? :Factory Self Test module
D2: 0 : Dr : -12: 0: 203: 82:Yes : Ok : Ok : 6D :25-05-06:6271? :Factory Self Test module
D2: 1 : Dr : -12: 1: 203: 82:Yes : Ok : Ok : 6D :25-05-06:6271? :Factory Self Test module
BB: 0 : Dr : -12: 0: 285: 82:Yes : Ok : Ok : B0 :25-05-06:6271? :Factory Self Test module
BB: 1 : Dr : -12: 1: 285: 82:Yes : Ok : Ok : B0 :25-05-06:6271? :Factory Self Test module
D9: 0 : Dr : -12: 0: 367: 76:Yes : Ok : Ok : 5E :25-05-06:6271? :Factory Self Test module
D9: 1 : Dr : -12: 1: 367: 76:Yes : Ok : Ok : 5E :25-05-06:6271? :Factory Self Test module
D4: 0 : Dr : -12: 0: 443: 75:Yes : Ok : Ok : C6 :25-05-06:6271? :Factory Self Test module
D4: 1 : Dr : -12: 1: 443: 75:Yes : Ok : Ok : C6 :25-05-06:6271? :Factory Self Test module
DC: 0 : Dr : -13: 0: 0: 70:Yes : Ok : Ok : 86 :25-05-06:6271? :Factory Self Test module
DC: 1 : Dr : -13: 1: 0: 70:Yes : Ok : Ok : 86 :25-05-06:6271? :Factory Self Test module
D0: 0 : Dr : -13: 0: 70: 69:Yes : Ok : Ok : 0C :25-05-06:6271? :Factory Self Test module
D0: 1 : Dr : -13: 1: 70: 69:Yes : Ok : Ok : 0C :25-05-06:6271? :Factory Self Test module
D3: 0 : Dr : -13: 0: 139: 69:Yes : Ok : Ok : 8D :25-05-06:6271? :Factory Self Test module
D3: 1 : Dr : -13: 1: 139: 69:Yes : Ok : Ok : 8D :25-05-06:6271? :Factory Self Test module
BA: 0 : Dr : -13: 0: 208: 83:Yes : Ok : Ok : 7C :25-05-06:6271? :Factory Self Test module
BA: 1 : Dr : -13: 1: 208: 83:Yes : Ok : Ok : 7C :25-05-06:6271? :Factory Self Test module
B9: 0 : Dr : -13: 0: 291: 71:Yes : Ok : Ok : 50 :25-05-06:6271? :Factory Self Test module
B9: 1 : Dr : -13: 1: 291: 71:Yes : Ok : Ok : 50 :25-05-06:6271? :Factory Self Test module
BC: 0 : Dr : -13: 0: 362: 72:Yes : Ok : Ok : B8 :25-05-06:6271? :Factory Self Test module
BC: 1 : Dr : -13: 1: 362: 72:Yes : Ok : Ok : B8 :25-05-06:6271? :Factory Self Test module
D8: 0 : Dr : -13: 0: 434: 70:Yes : Ok : Ok : D3 :25-05-06:6271? :Factory Self Test module
D8: 1 : Dr : -13: 1: 434: 70:Yes : Ok : Ok : D3 :25-05-06:6271? :Factory Self Test module
FD: 0 : Dr : -14: 0: 0: 64:Yes : Ok : Ok : 9F :25-05-06:6271? :Factory Self Test module
FD: 1 : Dr : -14: 1: 0: 64:Yes : Ok : Ok : 9F :25-05-06:6271? :Factory Self Test module
FB: 0 : Dr : -6: 0: 510: 32:Yes : Ok : Ok : 72 :25-05-06:6271? :Factory Self Test module
FB: 1 : Dr : -6: 1: 510: 32:Yes : Ok : Ok : 72 :25-05-06:6271? :Factory Self Test module
E6: 0 : Dr : -10: 0: 506: 32:Yes : Ok : Ok : 1A :25-05-06:6271? :Factory Self Test log
E6: 1 : Dr : -10: 1: 506: 32:Yes : Ok : Ok : 1A :25-05-06:6271? :Factory Self Test log
E7: 0 : Dr : -12: 0: 518: 32:Yes : Ok : Ok : 21 :02-09-06:6271? :Factory Self Test parameters module
E7: 1 : Dr : -12: 1: 518: 32:Yes : Ok : Ok : 21 :02-09-06:6271? :Factory Self Test parameters module
BE: 0 : Dr : -10: 0: 538: 21:Yes : Ok : Ok : BB :25-05-06:6271? :Factory Self Test module
BE: 1 : Dr : -10: 1: 538: 21:Yes : Ok : Ok : BB :25-05-06:6271? :Factory Self Test module
B8: 0 : Dr : -3: 0: 677: 2:No : : : : : :Single Plug Test Communication Module
B8: 1 : Dr : -3: 1: 677: 2:No : : : : : :Single Plug Test Communication Module
BF: 0 : Dr : -6: 0: 542: 8:Yes : Ok : Ok : EB :25-05-06:6271? :Factory Self Test module
BF: 1 : Dr : -6: 1: 542: 8:Yes : Ok : Ok : EB :25-05-06:6271? :Factory Self Test module
FC: 0 : Dr : -6: 0: 550: 4:Yes : Ok : Ok : C5 :25-05-06:6271? :Factory Self Test module
FC: 1 : Dr : -6: 1: 550: 4:Yes : Ok : Ok : C5 :25-05-06:6271? :Factory Self Test module
EE: 0 : Dr : -6: 0: 554: 4:Yes : Ok : Ok : 0B :25-05-06:6271? :RRO Data Log
EE: 1 : Dr : -6: 1: 554: 4:Yes : Ok : Ok : 0B :25-05-06:6271? :RRO Data Log
E1: 0 : Dr : -33: 0: 0: 510:Yes : Ok : Ok : 69 :25-05-06:6271? :Factory Self Test defects log
E1: 1 : Dr : -33: 1: 0: 510:Yes : Ok : Ok : 69 :25-05-06:6271? :Factory Self Test defects log
E2: 0 : Dr : -34: 0: 0: 510:Yes : Ok : Ok : B6 :25-05-06:6271? :Factory Self Test defects log
E2: 1 : Dr : -34: 1: 0: 510:Yes : Ok : Ok : B6 :25-05-06:6271? :Factory Self Test defects log
E3: 0 : Dr : -35: 0: 0: 510:Yes : Ok : Ok : 4D :25-05-06:6271? :Factory Self Test defects log
E3: 1 : Dr : -35: 1: 0: 510:Yes : Ok : Ok : 4D :25-05-06:6271? :Factory Self Test defects log
E4: 0 : Dr : -36: 0: 0: 510:Yes : Ok : Ok : 1C :25-05-06:6271? :Factory Self Test defects log
E4: 1 : Dr : -36: 1: 0: 510:Yes : Ok : Ok : 1C :25-05-06:6271? :Factory Self Test defects log
E5: 0 : Dr : -37: 0: 0: 510:Yes : Ok : Ok : E7 :25-05-06:6271? :Factory Self Test defects log
E5: 1 : Dr : -37: 1: 0: 510:Yes : Ok : Ok : E7 :25-05-06:6271? :Factory Self Test defects log
E9: 0 : Dr : -38: 0: 0: 469:Yes : Ok : Ok : 25 :25-05-06:6271? :Factory Self Test head 1 defects log
E9: 1 : Dr : -38: 1: 0: 469:Yes : Ok : Ok : 25 :25-05-06:6271? :Factory Self Test head 1 defects log
EA: 0 : Dr : -39: 0: 0: 469:Yes : Ok : Ok : 44 :25-05-06:6271? :Factory Self Test head 2 defects log
EA: 1 : Dr : -39: 1: 0: 469:Yes : Ok : Ok : 44 :25-05-06:6271? :Factory Self Test head 2 defects log
EB: 0 : Dr : -40: 0: 0: 469:Yes : Ok : Ok : E4 :25-05-06:6271? :Factory Self Test head 3 defects log
EB: 1 : Dr : -40: 1: 0: 469:Yes : Ok : Ok : E4 :25-05-06:6271? :Factory Self Test head 3 defects log
EC: 0 : Dr : -41: 0: 0: 469:Yes : Ok : Ok : 2B :25-05-06:6271? :Factory Self Test head 4 defects log
EC: 1 : Dr : -41: 1: 0: 469:Yes : Ok : Ok : 2B :25-05-06:6271? :Factory Self Test head 4 defects log
ED: 0 : Dr : -42: 0: 0: 469:Yes : Ok : Ok : 8D :25-05-06:6271? :Factory Self Test head 5 defects log
ED: 1 : Dr : -42: 1: 0: 469:Yes : Ok : Ok : 8D :25-05-06:6271? :Factory Self Test head 5 defects log
DE: 0 : Dr : -14: 0: 64: 104:Yes : Ok : Ok : 4F :25-05-06:6271? :Factory Self Test module
DE: 1 : Dr : -14: 1: 64: 104:Yes : Ok : Ok : 4F :25-05-06:6271? :Factory Self Test module
FA: 0 : Dr : -14: 0: 168: 256:Yes : Ok : Ok : D0 :25-05-06:6271? :Butterfly Log
FA: 1 : Dr : -14: 1: 168: 256:Yes : Ok : Ok : D0 :25-05-06:6271? :Butterfly Log
Zone allocation table
HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED"
MODULES DIRECTORY (01)
SA Copy num Location State
0 c: -1 H: 0 Ok
1 c: -1 H: 1 Ok
Modules number.......................... : 107
CONFIGURATION MODULE (02)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
HDD Identify
Model................................... : WDC WD2500JS-60NCB1
Serial number........................... : WD-WMANK4288533.....
Logical parameters...................... : LBA : 488 397 167
Master-password
Set..................................... : No
User-password
Security level.......................... : High
Log DCM (C5)
0 c: -1 H: 0 Ok
1 c: -1 H: 1 Ok
Hawk HWK
+-------------- Drive Head DCM Codes -------------+
| ALPS : A, FTemp: 1 (0 offset)|
| ALPS NON: H, J, L, R FTemp: 2 (non-0 offset)|
| HEADWAY : 8, D FTemp: 3 (0 offset)|
| WDB : 0, 7, F, Y FTemp: 4 (0 offset)|
| WDB-HBMT: M, N, P FTemp: 5 (0 offset)|
| ZR89 : U FTemp: 6 (0 offset |
P-List (33)
0 c: -2 H: 0 Ok
1 c: -2 H: 1 Ok
Defects number.......................... : 376
G-List (34)
0 c: -1 H: 0 Ok
1 c: -1 H: 1 Ok
Defects number.......................... : 0
Re: WD2500JS-60NCB1 sounds well but not recognized
Postby AJ2008 » 08.07.10, 15:03
All these modules not read, and many are very important to HDD operation. You have Overlays, defect tables and other adaptive info not read. I think there my be some other hardware error here, if no other hardware error and all modules actually bad I do not think data access can be made.
Maybe you can try read Plist alone to donor and regen translator on donor and maybe you will be lucky with hotswap if donor is close match...
rcz
Postby rcz » 08.07.10, 16:00
So I think I'm lucky :roll: .
I did it: it produces many ABRT errors but it seems there is no shift, I managed to open few photos without errors.
I'll report the result or if I have troubles.
Thanks a lot :!:
Postby AJ2008 » 08.07.10, 16:53
Good job 8)
