ST3100528AS CC37
zeroalpha
ST3100528AS CC37
Postby zeroalpha » 08.07.10, 12:32
This drive comes ready and I can do a db backup, but no access to surface
Rst 0x20M
SIM Error 1002
(P) SATA Reset
SIM Error 1002
SIM Error 1002 PASS
SIM Error 1002
SIM Error 1002
SIM Error 1002WriteDCOInfo FAILED during Initialization
RW: Error processing Performance Parameter File: 203C PASS
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
SIM Error 1002
zeroalpha
Re: ST3100528AS CC37
Postby zeroalpha » 12.07.10, 14:05
I figured out the solution.
datacare
Postby datacare » 15.07.10, 07:13
I am also facing same problem. can you tell me how to solve this one.
Sundar
Data Care Services
Issam
Postby Issam » 18.07.10, 00:17
heads should be replaced
Postby AJ2008 » 19.07.10, 12:40
Issam wrote:heads should be replaced
This is not the case, heads are not damaged.
I remember similar case I had and repaired with old translation repair command, 'm0,2...'. In my case I had full ID also.
