help with f1_d3 hdd
help with f1_d3 hdd
i have a samsung hd103uj which burn't the pcb, i have change the pcb from exact identical donor but the hdd is in bsy mode and i cannot work with it! did anyone has found a similar problem or can undestood what is going wrong?
Re: help with f1_d3 hdd
I think ROM are not compatible. I do not have one of these to confirm, but havent these got embedded ROM in processor?
I think hotswap may be possible to get SA access, and here you can access SA module required for data access from hot-swap?
Do you have Terminal report of pateint disk with donor PCB?
i had try hot swap but didn't work. please tell me the procedure for hot swap to check if i did it correct!
also i don't have terminal report, does this family has the ability to connect terminal and how? which adapter?
i was trying hot swap and i got this terminal output when trying to read modules:
"qEr 1340
Error. start sector 1 num of okay sector= 0 unread sector=1
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
Error. start sector "
did anyone understood what is going wrong?
"qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
qEr 1340
