I have had a few of these drives with this error and still cannot work out how to fix it with the PC3000.
When the box comes up explaining what to do (confusing as it is)
I short circuit the two contacts and press "start proceedure".
The motor stops and starts again and then I get a series of F3 T> down the page.
I then get an input error (still short circuited)
Then the drive becomes ready and it repeats the F3 T> down the page again, but spindle does not stop.
Do I continue short circuiting until the spindle motor stops(if it ever will), or do I press try again? Or do I just proceed with the repair even though the spindle has not stopped?
Have I short circuited at the wrong time?
Although the drive has become ready, it detects as Mb().
Any help would be greatly appreciated.
Seagate 000000cc error (new feature)
Re: Seagate 000000cc error (new feature)
Same problem here too.
Igor whats the purpose of the new procedure?
Looks like its back to the manual method in the meantime.
I cannot tell whether there is any scripting changes in "BUSY ERROR" solution - only dialog change with pictures.
Some 7200.11 drives will take several tries to come ready using read channel short method.
Keep trying
Keep trying
With new solution you can solve LED CC problem on ES.2 drives automatically.
General sequence is next:
Press "start procedure"
When you have seen F3>T you should short the points. Short the points before LED CC appearance. When you have made short, LED CC message should not appears. If it appears you should make solution from the start.
Keep short till motor has stopped.
Then remove the short and press "ready".
You should use for making the short tweezers with held clip like on pictures (it is very important).
Users browsing this forum: No registered users and 19 guests
