ST3250310NS -ES.2, FIRMWARE:-HPG2 PROBLEMS
datacare
Postby datacare » 12.05.10, 10:53
Is there any solution to solve this problem
Thanks & Regards
Sundar Rajan.P
Datacare Services
Re: ST3250310NS -ES.2, FIRMWARE:-HPG2 PROBLEMS
Postby AJ2008 » 12.05.10, 11:22
What you see is the disk initialsing from ROM alone. This could be for a number of reasons:
1. HDD has LED:CC error
2. HDD has non native PCB
3. Heads damaged
If there is no knocking I would assume it is LED:CC error. for this you require shorting of the reading channels. This process is automated in newest release of PC3000. Also, in your manual you will find shorting points.
