Hi all,
If I want to do a hotswap to image user data, which modules need to be copied from the original drive to the donor drive?
(WD10EADS-00L5B1).
So far I have tried 31, 32 and 36 but when I try to access user data the original drive just clicks. All heads are fine (at least tested within KERMIT utility).
Orinially the drive was spinning up, no clicking but no recognition, no SA access. SA access only via hotswap. I managed to get most of the modules but there seem to be a lot of damaged modules.
Any help appreciated!
Thank you in advance!
Marvell Hotswap - which modules?
Re: Marvell Hotswap - which modules?
What are the modules that are damaged and can't be read?
These modules are damaged on both copies:
Module 1E (Loaded part of microprogram c : Module 001E reading error ABA 390087 reading error - Device Error Detected: "DISK DAM ERROR"
Module 1E............................... : Error
Module 2F (Loaded part of microprogram c : Module 002F reading error ABA 390093 reading error - Device Error Detected: "DISK DAM ERROR"
Module 2F............................... : Error
Module 2A (Loaded part of microprogram c : Module 002A reading error ABA 390099 reading error - Device Error Detected: "DISK DAM ERROR"
Module 2A............................... : Error
Module 23 (S.M.A.R.T. Log (reserved))... : Module 0023 reading error ABA 390251 reading error - Device Error Detected: "DISK DAM ERROR"
Module 23............................... : Error
Module 13 (Loaded part of microprogram c : Module 0013 reading error ABA 390397 reading error - Device Error Detected: "DISK DAM ERROR"
Module 13............................... : Error
Module 80 (Loaded part of microprogram c : Module 0080 reading error ABA 390452 reading error - Device Error Detected: "DISK DAM ERROR"
Module 80............................... : Error
Module 11 (Loaded part of microprogram c : Module 0011 reading error ABA 390464 reading error - Device Error Detected: "DISK DAM ERROR"
Module 11............................... : Error
Module 121.............................. : Module 0121 reading error ABA 387455 reading error - Device Error Detected: "DISK DAM ERROR"
Module 121.............................. : Error
Module 2001............................. : Module 2001 reading error ABA 376878 reading error - Device Error Detected: "DISK DAM ERROR"
Module 2001............................. : Error
Module 2002............................. : Module 2002 reading error ABA 374545 reading error - Device Error Detected: "DISK DAM ERROR"
Module 2002............................. : Error
Module 2003............................. : Module 2003 reading error ABA 372943 reading error - Device Error Detected: "DISK DAM ERROR"
Module 2003............................. : Error
Module 2005............................. : Module 2005 reading error ABA 370219 reading error - Device Error Detected: "DISK DAM ERROR"
Module 2005............................. : Error
Module 2006............................. : Module 2006 reading error ABA 368141 reading error - Device Error Detected: "DISK DAM ERROR"
Module 2006............................. : Error
Module 2007............................. : Module 2007 reading error ABA 366543 reading error - Device Error Detected: "DISK DAM ERROR"
Module 2007............................. : Error
Module 2020............................. : Module 2020 reading error ABA 366463 reading error - Device Error Detected: "DISK DAM ERROR"
Module 2020............................. : Error
Module 2021............................. : Module 2021 reading error ABA 366381 reading error - Device Error Detected: "DISK DAM ERROR"
Module 2021............................. : Error
Plus these are "yellow":
1F, 61, 62 6E, 93, 94, 98, 99, CA, CB, CC, CD, CE, CF
Have you tried head map changing in RAM on this one?
Try to load a LDR before SA access.
