RAW RECOVERY by Header Information
ZeBong
Postby ZeBong » 04.02.10, 01:22
Hi to all,
i would like to know if is possible in DE to make a raw recovery by header information
I can see the files Header Information in Hex Decimal,
Example
JPEG Images
ff d8
but i dont find any place in DE where i can put or build my own file type.
i would like to know how other users make this.
Jose
zeroalpha
Re: RAW RECOVERY by Header Information
Postby zeroalpha » 05.05.10, 12:56
Can't you click on the "Raw Recovery Reference Book" button under the raw recovery mode? It gives a grep menu and you can add your signatures?
sempre
Postby sempre » 18.05.10, 16:02
Hi to all!
Open a good edithexa remove copy grep to add the raw Recovery Reference Book in DE.
I hope I have contributed...
nothing is impossible!
Postby AJ2008 » 18.05.10, 17:59
sempre wrote:Hi to all!
The Grep and the file header from a hex editor are not the same. they are structured differently, GREP (I think) seperates bytes with a '/' while a Hex Editor does not so copying the information exactly will not work.
I think tech support at Acelab should be able to clarify this one.
sempre
Postby sempre » 18.05.10, 22:34
hi, sorry,
In winhex is function menu edit =>copy block=> GREP HEX
Is correct?
Please opnions...
Thanks!! :mrgreen:
Return to “Data Extractor”
