MP0603H translator issue?
pcimage
Postby pcimage » 22.01.10, 12:57
Hi!
Got one of these in, with the typical Magma v3 PCB problem, not quite spinning up to speed.
Replaced PCB with one of same FW (UD100-11) and it spins up but stays BSY. Terminal looks normal but it never gets to "ENG>" prompt just sits there.
So, I hot-swapped to get modules and performed a smart hot swap after copying the appropriate modules to a donor.
All looked good up untill ~10.5 million sectors, then not one readable thereafter.
Head config is the same (i.e. 1,0,3 - H2 missing)
Now to me this looks like a translator issue but these have dynamic translator, right?
Not had a Samsung with this sort of issue in before.
Any ideas?
pcimage
Re: MP0603H translator issue?
Postby pcimage » 22.01.10, 17:09
Repaired original PCB, problem solved :-)
