Hi to all,
I have this disk and i have a donor with the same site code:
After the head change i could not get read the surface, and i match the site code.
I notice that the stick in the pre amp is different.
Would like to know how other people use this for matching the heads.
Jose
SEAGATE 7200.12 - Heads Match
Re: SEAGATE 7200.12 - Heads Match
Did you match the first three digits of serial number?
yes i try that
also the site code
and the pre amp ID
nothing
also the site code
and the pre amp ID
nothing
Have you already solved this matter ?
