I have ST31000340AS 0MB problem
hamidrcr
Postby hamidrcr » 04.12.09, 23:17
MDL ST31000340AS
FW ST 35
In the beginning this media has BSY problem.
It did resolve but now it is showing me 0MB and unable to fix.
I did refer PC3K user manual and short circuit in PCB as per it said in manual.
Now I am getting following msg.
Test : Solution for problem "Translation violation (0 GB)"
HDD capacity restrict. check (SetMax)...
HDD capacity restrict. check (SetMax)... : Error
SMART erase............................. : Ok
COM port reconnection...
Error : Terminal : error detecting HDD terminal baud rate
Solution for problem "Translation violation (0 GB)"......... : Error
Any one can help me in this case plz.
Re: I have ST31000340AS 0MB problem
Postby AJ2008 » 10.12.09, 09:19
There is no need for shorting of PCB in this case. Does HDD knock the heads on powering?
If HDD powers, calibrates and remains powered with no knocking then I think you can resolve this by entering translation repair command manually. Maybe you can up the write retries if you have problems.
